Samsung 400DXN-2 LH46BVTLBC/EN - Magic info problem
  • gemcka
    • Mar 2016
    • 5
    • Wales
    Hi All,
    I'm hoping you will be able to help me with this problem..
    We have had this Samsung display for some years now - we've been using it as a power point presentation screen using the inbuilt PC.
    Recently the PC has stopped working with nothing showing on the display.
    With source set to 'MagicInfo' it simply says "No Signal".
    I have tested the HDD and it spins up OK and can be read when connected to my PC.
    The power seems OK - All the fans start up and hdd spins when I turn the tv on.
    I have recently been told it was the main PC board that was faulty so I have replaced it with a new one (new-read supplied as removed from working TV and tested from store)
    Part no BN41-01250A Megatron Board.
    But after replacing this the issue remained.
    I was then told it was a HDD fault - but I don't see any errors and don't even see any sign of it attempting to boot, and as i mentioned before, I can plug the hdd into my pc via a usb converter - and can read it without any problems.
    does anyone have any ideas??
    Many Thanks for any help
    Gav
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung 400DXN-2 LH46BVTLBC/EN - Magic info problem
    It may be worth reading through the manual and checking everything is still in place needed for it to run.
    Can you connect an external monitor to the video out of the PC motherboard?
    • gemcka
      • Mar 2016
      • 5
      • Wales
      Everything 'looks' ok and all the connections are good - I have plugged in an additional monitor to the VGA out and the screen just stays in standby mode.
      as if, waiting for a signal...
      thanks
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The initial suggestion of hard disk problem could be correct. If the MBR (Master Boot Record) of the hard disk is damaged then the PC won't boot up. However you could still read all the data held on it when plugged in to another PC since it now acts as a slave device.
        If you do a reset on your PC can you hear the hard drive spinning up or see any led flashing?
        Can you get into the Bios by pressing the Del key or F2 when rebooting? At least that should show up on the external monitor if you mother board is working.
        • gemcka
          • Mar 2016
          • 5
          • Wales
          I have tested the HDD in another PC and I can see the Windows XP startup screen so I'm pretty sure it's not the HDD at fault.
          I'll re-build it and see if I can get anything to come up on a separate screen when booting into bios - but I don't think anything is shown on the screen, it's as if POST doesn't happen..
          Gav
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            It's nothing obvious but possibly overlooked like the PC power supply faulty?
            • gemcka
              • Mar 2016
              • 5
              • Wales
              Yes - i'm thinking the same thing now...
              I've checked the PC on boot and other than the fans and HDD spinning up it looks lifeless!
              No POST process, no chance to enter the bios on a linked screen and no lights on the keyboard or mouse.
              however...........something strange looks to be happening..
              If I turn on the screen with the MagicInfo source selected - nothing happens...
              when trying to check the bios, I turned on the screen and pressed all the usual keys to get into the bios, F11, F12, Esc etc.. nothing happens. no lights on the keyboard or the attached mouse. but after a couple of minutes the board 'Clicks' and it comes back to life!?
              all working as it should - PC, network connection etc All normal.
              If you turn the Screen off and back on again - nothing.
              Only when you connect a keyboard and press keys after you start the screen does it seem to work properly?!!?
              Although after turning it off the last time I can't get it to start properly again.
              but it is showing a different message on the screen - instead of "No Signal"
              it says "Not Optimum Mode - Recommended Mode 1920 x1080"
              I don't know how to change any of this settings??
              • Diah
                • Feb 2013
                • 6614
                on this model to inter Bios hit F2 at booting up.
                to solve this issue and any other issue.. would be solved by Factory reset.
                for this you need 2GB USB and Dos start file and Tool SFIM.exe and Operating system Image when all on USB and make via the BIOS boot from USB
                hi command
                SFIM / r: 1 dxn.sfi / s
                then turn off the screen when the process finished.
                log in Bios and move ALL USB KEY to lowest priority.
                  09-07-2024, 05:50 AM
                • howardc64
                  Samsung UN55JU650DF network/streaming problem
                  by howardc64
                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                  07-09-2025, 12:44 PM
                • alro7779
                  Samsung UN55MU6103F video problem; has colored stripes on the display
                  by alro7779
                  Hello, everyone!
                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                  09-27-2025, 11:29 PM
                  09-06-2024, 11:40 PM
