Samsung PS50A557S3F
  • ukvince
    Learning
    • Jun 2011
    • 31
    Samsung PS50A557S3F
    Been looking at this tv for a friend. It powers up, blue light is steady. and all voltages are present and correct but there's no picture. After much deliberation I knew that the problem must be either the y-sus or buffer or both... I had already checked all of the caps / mossfets etc on the x and y-sus boards but found no issues there but a more in-depth check of the y-sus (LJ92-01549A) found that 3 of the smd diodes are short. These are D5029 / D5030 and D5040. They all have the same markings which are K4 8G, which i believe are rectifier diodes.
    I want to replace these just for the hell of it (before i buy a new board) but I can't find any info on them anywhere so if anyone can help and tell what the specs are for these diodes I would be grateful.
    Here's a pic of the offending items...
    Thanks in advance...
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Samsung PS50A557S3F
    Check them out of circuit first
    I believe this is what you have but would definitely want a double confirmation on that. This is your K4
    • ukvince
      Learning
      • Jun 2011
      • 31
      I checked them out of circuit and they are fine....i get continuity across the pads that they sit on...back to head scratching...
        09-07-2024, 05:50 AM
      • Dvsr
        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
        by Dvsr
        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
        After replacing the caps I started testing out the speaker. It seemed...
        09-10-2025, 10:20 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
