Replacing HDMI ports on main boards
  • tech2014
    • Aug 2014
    • 807
    Does anyone know where I can find new HDMI ports to replace on main boards. A customer has a main board on an LG 60PB5600 plasma that has a broken HDMI port.
    These boards are very costly so is there a place that sells replacement HDMI ports, and is it worth it. Will I just do more damage to the board trying to remove the original and install a new one.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Replacing HDMI ports on main boards
    Use hot air and flux to remove old port.
    Clean out solder and support pads with desoldering iron and wick.
    Slide new port in.
    Solder support pads make sure port it lined up over solder pads properly when doing so.
    Apply flux to pins.
    Apply small amount of solder to clean iron tip.
    Drag solder out across pins.
    Remove any solder bridges with wick and more flux.
    Clean with ipa.
    Check with MS to make sure all is soldered.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Its easy stuff, use a few scrap boards to practice first its not easy it you have never done it before.
      • tech2014
        • Aug 2014
        • 807
        I have done a LOT of repairs using hot air, so no worries there bud. I just need to find a replacement port.
        Also, what temp should I set my hot air too? I don't want to fry the board.
        • diif
          • Feb 2014
          • 6978
          • England
          I have my hot air about 360/380c. However the easiest way to remove a damaged HDMI port is to mask off the rest of the board to protect it from metal shavings and use the cutting tool like a Dremel to remove the bulk of the connector, then hot air the rest easily, this reduces risk of over cooking the board. Or use pre heat the whole board before using hot air.
          I bought a bag of assorted HDMI sockets from Aliexpress.
          Alternatively look for a faulty board on ebay perhaps to pull an HDMI socket off.
          • Wittie
            Philips 55OLED803/12 HDMI ports "half" defective
            by Wittie
            Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
            03-19-2025, 09:38 AM
          • Yanleb
            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
            by Yanleb
            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
            If they are not compatible why did Samsung give them the same part number to begin with?
            08-04-2025, 11:35 PM
            Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
            09-06-2024, 09:40 AM
