VESTEL FIRMWARE: Toshiba 22D1333B
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: VESTEL FIRMWARE: Toshiba 22D1333B
    Originally posted by RAZ777
    Hi Guys,
    I have a toshiba 40l3653db with flashing green light, found this forum & thread searching google unsucessfully for firmware.
    Can anyone help, point me to any appropiate firmware?
    Thank you
    Hi welcome to badcaps can you also post your request in this thread https://www.badcaps.net/forum/showth...ghlight=eeprom
    it will also help if you can let us know what mainboard is used in this set and also on the back metal part of the lcd panel chassis there should be a white sticker that will tell us what lcd panel is used in your tv.
    • RAZ777
      • Feb 2022
      • 18
      • uk
      Hi
      Its the vestel 17MB110 main board, screen is VES400UNDS-2D-N12
      Thank you
      • peterkos2
        • Nov 2020
        • 43
        • Slovensko
        Originally posted by ReeceyBurger123
        Firmware File:
        Great, this helped.TV came alive
        I just can't do many things - tuning, sound...
        Does anyone have a refill for the SPI memory board 17MB95M for the Finlux TV 22FLHZR274LVCW
        panel M215HGE-L21?
        well thank you
        • anlu
          Vestel Firmware - Toshiba 32W133DN
          by anlu
          Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
          Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
          02-04-2023, 12:59 AM
        • cheeky2
          Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
          by cheeky2
          I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
          Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
          The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
          Details:...
          08-17-2023, 04:34 AM
        • Bazilwrc164
          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
          by Bazilwrc164
          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
          If anyone can provide:
          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
          • Or a compatible EEPROM dump
          07-23-2025, 12:15 PM
        • RAZ777
          Toshiba 40L3653DB Vestel firmware
          by RAZ777
          Hi Guys,
          I have a Toshiba 40L3653DB with flashing green/red led - firmware fault.
          It has the vestel 17MB110 board.
          Anyone know where I could get firmware?
          02-16-2022, 07:56 AM
        • DarrenHD
          Firmware for older Toshiba TV 22CV100U
          by DarrenHD
          HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
          I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
          https://support.dynabook.com/support...tentId=2865076
          Thanks!
          06-16-2025, 11:56 AM
