LG 50PV250 Y Buffer meltdown
  • mangozac
    • Feb 2013
    • 36
    We were watching TV the other night and *bang* (as in made an actual noise), no more picture. Sound was still working but the ominous smell of vaporised semiconductor hung in the air!
    Popped the back off and sure enough the top Y Buffer ICs had a big hole in it. I turned power back on and could see one of the buffers on the bottom half starting to glow too. So I removed both buffer boards and tested the Y-sus voltages Vy and Vsc, both of which were in spec at 150 and -190V (Vsc is confusing as measuring with the polarity indicated on the PCB it actually gives a positive voltage).
    My question to you knowledgeable fellas is this: do I just source new Y buffer boards or is it likely there's something else wrong with the Y Sus board that isn't obvious and damaging the buffers? Is one fried buffer likely to cause the rest to pop? The reason I ask is because that Y Sus board doesn't seem particularly common so could be a headache to replace.
    The Y Sus board is a EBR69839001
    The buffer boards are EBR69839101 and EBR69839201
    Thanks!
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: LG 50PV250 Y Buffer meltdown
    I may have those..let me check.
    • mangozac
      • Feb 2013
      • 36
      Cheers mate, let me know what you find!
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Mine are different...2010 model..numbering system is even different.
        • mangozac
          • Feb 2013
          • 36
          Thanks anyway. Do you reckon I need to change the Y Sus board too, to make sure the new buffers don't get fried?
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Yanleb
            Schematic or datasheet for Plasma TV buffer chip
            by Yanleb
            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
            05-18-2022, 01:36 PM
          • gatto
            LG 50PC56 keep burn Buffers Boards
            by gatto
            Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
            I have this LG 50PC56 which not display image on screen
            I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
            When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
            My question it is: I disconnect...
            05-04-2022, 01:35 AM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
