X-Main (LJ41-07015A) repair on my Samsung Plasma PN50B400P3D
  • chico1st
    • Jan 2012
    • 21
    Has anyone successfully repaired a X-Main (LJ41-07015A) from a Samsung Plasma PN50B400P3D.
    I had no power on my TV and a clicking relay and I have narrowed it down to this board.
    If anyone has repaired one before, has a schematic it would be useful or know general issues with 2009 ish Samsung Plasma TVs.
    I attached an image of the board from shop Jimmy.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: X-Main (LJ41-07015A) repair on my Samsung Plasma PN50B400P3D
    Do you have a DMM and know how to check for S/C aka short circuit ?
    • chico1st
      • Jan 2012
      • 21
      Yeah I have a multimeter and know how to use it.
      I havent started pulling parts off yet.
      Repairing parts in unknown schematics is new to me though. I assume I basically need to pull everything off to check them but I was hoping to know where to focus my efforts.
      This is what i know so far:
      -The chassis ground seems to be pretty much shorted to Vs (it has a bunch of 150uF 250V electolytic caps between it and chassis ground)
      - The Vs rail also goes to the collector of some IGBT (RJP30E2DPP-M0) Q4301
      -The gate of that IGBT goes so a rail that is connector to every pin of the 'HD' connector and every pin of the buffer board connector). This rail is also shorted to ground.
      • chico1st
        • Jan 2012
        • 21
        Also worth mentioning came to the conclusion that I was the X-main board by just plugging and unplugging the internal boards using the start up chimes as a sign that it was working.
        the X buffer may be broken too...or whatever the 'HD' connector goes to but unplugging them and leaving x-main attached still resulted in no power and a clicking relay.
        • chico1st
          • Jan 2012
          • 21
          I successfully repaired this board. I wanted to change the title to be the PCB ASSY number instead of the PCB bare board number. Is there a way to update the title?
          Then I will just dump my repair notes into this thread.
          • chico1st
            • Jan 2012
            • 21
            OK the failure for this seemed to be a blown fet in the pull of the push pull driver which blew all the fets in the push pull and the driven impedance matching circuit (which goes to net ERC but I have no idea what that is).
            In general i replace R4502 and R4102 with 15 ohm resistors since they were tied to Vcc in the failed condition and blew. Luckily the SO233 parts near it were fine.
            I also replaced the four 360V push pull IGBTs with FGPF4536 since the originals were obsolete.
            Q4302,Q4301,Q401,Q4014
            The 2 IGBTs on the impedance matched driver with FGPF4533
            I forget the component numbers but they were the only two 3 legged through hole ICs near C4505 and C4506.
            The PCBA# for this board was LJ92-01727A and the LJ41# i referenced in the title was just the # for the bare board.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              X-SUS is 'H' Bridge, (Not push-pull) with other stuff like ERC circuit...
              TELEFIX
              • chico1st
                • Jan 2012
                • 21
                Hmm fair,
                I have no idea what the ERC is connected to since it seems to not connect to anything on the X main and thats the only circuit i looked through. A lot of the power seems to travel to the Y main. What does the ERC control? A general current to the plasma? Why would you need to H bridge it, can plasma go backwards?
                • masaudio
                  • 16
                  • England
                  Just done the same board..
                  Replaced similar parts plus a few others..
                  The 2 surface mount resistors, R4102, R4502, 15 ohm.
                  D4103, D4302 STTH1004FP
                  Q4503, Q4504 30F123
                  D4202, D4505, D4901 RF1501
                  Q4101, Q4104, Q4201, Q4301, Q4302 RJP30E2
                  Thanks, Mark.
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
