Samsung PS58C6500TK pink banding issue and more
  • Baileybum1234
    • Sep 2012
    • 245
    Ok so I have a Samsung PS58C6500TK.
    It had the pink banding issue please see attached pic.
    I was looking at another forum and they suggested updating the control board firmware - I did this.
    Excuse multiple post but trying to keep the stages I have taken separate.
    Repaired: LG50PQ6000
  • Baileybum1234
    • Sep 2012
    • 245
    Re: Samsung PS58C6500TK pink banding issue and more
    This only partly fixed the issue. So I adjusted VS as the next step.
    It was originally at 206.9 when it should be at 209.
    I took it up to 209 then to 213 and back down to 209 and the fault remained during this process.
    • Baileybum1234
      • Sep 2012
      • 245
      The issue is still a pink distortion that comes and goes with different colours.
      Im starting to think there was more than one original problem.
      Mostly at the top but some times running down through the screen.
      There also looks like there might be wavy lines in the pictures. I think these happen so fast I cant see them there is deffinately something up!
      There is distortion on the pictures due to mains Hz so please ignore the vertical bands thay are only in the pictures and not on the screen.
      • Baileybum1234
        • Sep 2012
        • 245
        Best pic I have of the internal boards at the moment.
        • Baileybum1234
          • Sep 2012
          • 245
          Ok,
          I have triggered the test pattern from the control board. The image still has the same fault.
          I made a video of the check:
          https://www.dropbox.com/s/qlhumfdk1d...%2041.mov?dl=0
            The wavy lines are a camera artefact due to the panel subfield refresh rate. You can ignore those (you may also see these if you "flick" your eyes across the panel.)
            Check the Vscan, Vs, Va and Ve voltages.
            • freakaftr8
              • Oct 2012
              • 3743
              That does not look like the classic pink banding symptoms that the Samsung panels are attributing. This looks like a control board malfunction. These bars are going vertically across the screen pink banding with the classic symptoms usually span horizontally
              • Baileybum1234
                • Sep 2012
                • 245
                Hi Tom,
                I will test those today and see what I get.
                Hi Freak,
                While I'm there do you know of a way I can check the control board with out replacing it?
                Cheers!
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Unfortunately I do not. If you can generate test patterns from the control board and like you show with the bars still there it looks like the right side is trying to mimic what the left is doing.
                  I suppose it could be something wrong with the panel also
                  • Baileybum1234
                    • Sep 2012
                    • 245
                    Hi Tom,
                    Tested results below:
                    Vscan: -199.7
                    Vs: 209V
                    Va: 55V
                    (Vb)Ve: 90.2
                    • Baileybum1234
                      • Sep 2012
                      • 245
                      Gulp not the PANEL!!!
                      • Baileybum1234
                        • Sep 2012
                        • 245
                        Originally posted by Baileybum1234
                        Hi Tom,
                        Vscan: -199.7
                        Vs: 209V
                        Va: 55V
                        (Vb)Ve: 90.2
                        They all look OK to me. Any thoughts any one?
                          Presumably these match the sticker.
                          Try Vs around 215V max, and increase Ve and Vscan (make Vscan more negative) max +/-15V on each
                          Also if the Y-sustain has Yrr / Yfr controls mark their original position then play around with them--try Yfr first
                          • Baileybum1234
                            • Sep 2012
                            • 245
                            Hi Tom yes they match the sticker.
                            I will have a play this evening.
                            • Baileybum1234
                              • Sep 2012
                              • 245
                              Hi guys sorry its been a while.
                              Just been busy with work and decorating little ones bed room.
                              Tom I managed to do a few tests but struggled to find the Yrr / Yfr controls and test points maybe you could point me in the directing if there on this model? I did do some searching on Google and apparently some screens dont have this adjustment?
                              OK Results so far:
                              Vs: adjusted +/- 15v and there was no change at all.
                              Vscan: adjusted -15v and + 6v (POT wouldnt allow further) no change at all.
                              Ve/Vb: adjusted +/- 15v and there was no change at all.
                              While adjusting the POT's I was watching the screen pink part of the image in a mirror and also keeping an eye on the DVM at the same time.
                              Also added a few more pics for your viewing pleasure. Does the direction of the pink band give any clues? There is also a fizzing noise coming from varions boards and it looks like the pink distortion is at the same frequency as the fizz/hiss. Again any clues?
                              Cheers. :0)
                              • Baileybum1234
                                • Sep 2012
                                • 245
                                When I run certain colours as a test background from a laptop the pink distortion doesn't show and the image is fine.
                                • Baileybum1234
                                  • Sep 2012
                                  • 245
                                  Any ideas folks still I'm still thinking on this one?
                                  Happy Christmas by the way !!
                                  • Baileybum1234
                                    • Sep 2012
                                    • 245
                                    I noticed a few threads having a little success by resoldiering the inductors?
                                    Might be the next port of call and a good visual inspection.
                                    • Baileybum1234
                                      • Sep 2012
                                      • 245
                                      So I pulled out these two boards for a visual inspection. I cant see any dry joints, anything burnt out or obvious.
                                      Running out of ideas to be honest! I could reflow the Inductors on the off chance but only going by something I saw on another thread for an LG screen. One leg of the inductors are covered with a piece or rubber awkwardly but could pull this off if it was worth while.
                                      Any further ideas out there??
                                      Could I swap a ribbon to see if the pink fault moves or is this not possible?
                                      Cheers
                                      Jarrett
                                        Inductors don't cause this fault on these Samsung sets, at least not seen any cases of it.
                                        You're kind of stuck because Samsung doesn't support much tweaking unlike Pioneer sets.
                                        You can't swap ribbons around, and anyway I doubt it would make any difference.
                                        Perhaps all you can do is adjust Cell Light to reduce these artefacts, this will also dim the panel somewhat.
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
