Lg 50pk750 help!!!!
  • LGinMD
    • Oct 2015
    • 26
    Lg 50pk750 help!!!!
    Hello all!
    Just wanted to start off by saying I love this site and look forward to enjoying many posts to come...
    Now, I have a LG 50" 50pk750 that will power up and stay powered up... The backlight comes on and the screen gets lighter but once the front led turns blue about 10secs later nothing happens... None of the front panel buttons do anything. Channel - +, Vol - +, Input, Menu... all do nothing. If I unplug the top Ysus buffer the top of the screen has static but no sound. If I unplug the lower Ysus buffer theres static on the lower and no sound. I get an 11 from the Control board LED which I havent the slightest as to what it means....
    Any and all help is appreciated!
    Thanks!
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg 50pk750 help!!!!
    An 11 on the control board?
    No idea what that means, the blinking led on the control board on an LG doesn't reveal any fault code.
    you can generate test patterns on this tv by connecting the 2 holes beside R51 and R52 on the control board. Make sure you disconnect the lvds cable.
    • LGinMD
      • Oct 2015
      • 26
      Will try that today... When you say the LVDs cable, what are you referring too?
      Also, if after connecting the two together nothing happens should I assume its the panel and not the YSUS board/ Buffers?
      Thanks!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        What exactly is the failure ? Tv becomes unresponsive ? If you unplug one of the Ybuffers only half the screen will work. Im confused can you please rephrase this. Cheers.
        • LGinMD
          • Oct 2015
          • 26
          I can post a video of it if need be... Ill try to list in order of what happens/what Ive done.
          1. Plugged in TV (Get Red LED on front).
          2. Push power on the touch panel.
          3. LED goes from Red to Blue (Relays Click)
          4. Screen turns an off greyish color (Backlight working?)
          5. Blue LED turns off but TV remains on (No image on screen or sound)
          6. After 10-15secs I can touch the different buttons on the touchpad (Input, Menu, Chan - +, Vol - +) and nothing happens but every time I push a button the led blinks as it sensing Im touching it..
          7. If I unplug the upper buffer from the YSUS board the upper part of the screen is black with speckles and the lower is still grayish..
          8. If I unplug the lower buffer from the YSUS board the lower part of the screen is black with speckles and the upper is still grayish...
          Ive measured VS, VA, -VY, VSC, and VBR all of which are in range...
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok alright thanks. Sounds like the Sustain boards are working which is why you are seeing "backlight" which is actually the pixels being primed up by the sustain boards. However it sounds like you either have a Mainboard or control board failure here. Can you upload pictures of the tv please.
            • LGinMD
              • Oct 2015
              • 26
              What is it youd like to see?
              Now the backlight doesnt stay bright for long... Say maybe 5 secs during startup then it dims to a faint grayish. It doesnt go black, the only time itll go black or "Off" is when the unit is switched off...
              The previous owner stated that the screen would dim sometimes while watching it then go back to normal. He also said that on occasion it would go black...
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Thats normal behavior, the screen starts the Pixels brighter. This is called priming this when the sustain boards ramp up voltage goes high to get the gases in the pixels ready to emit light. This priming process on Lg's lasts ablut 5 seconds then the sustain boards will lower and the tv should operate normally. Do you even see anything displayed on the screen ?
                Pictures of the boards.
                • LGinMD
                  • Oct 2015
                  • 26
                  • LGinMD
                    • Oct 2015
                    • 26
                    Nothing on the screen... Again, regardless of what button I push on the front panel the screen remains the same (Nothing)..
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok is there a flashing Led on the Control board ?
                      • LGinMD
                        • Oct 2015
                        • 26
                        Yes, I stated that in my initial post... It flashes 1 long then 1 short (11)
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Alright ok sounding more and more like a Mainboard fault. Do what Hamie said and see if test patterns work.
                          • LGinMD
                            • Oct 2015
                            • 26
                            Will do, not to sound stupid but which cable is the LVDS cable?
                            Also, given the two scenarios if the test patterns work then whats next?
                            If the test patters dont work then whats next?
                            • Hamie
                              • Apr 2014
                              • 1383
                              Just to clarify for test Patterns.
                              On the control board disconnect the LVDS cable. This cable is labelled P31.
                              The 2 holes you need to connect together with a paper clip or bit off wire are close to P31 beside the 2 resistors marked R51 and R52.
                              If you get test patterns you have a faulty mainboard.
                              Unfortunately the board is usually quite expensive as it in high demand.
                              • LGinMD
                                • Oct 2015
                                • 26
                                Never mind I got it, P704 cable is the LVDS cable.. Just remove that cable and test by jumping the two stated earlier?
                                EDIT: Just saw your post Hamie, thanks!
                                • LGinMD
                                  • Oct 2015
                                  • 26
                                  Ok removed the LVDS cable and jumped the R51/52 holes and nothing happened. With the cable disconnected the LED on the front panel doesnt even light up.
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Can you post a picture of what you've done.
                                    • LGinMD
                                      • Oct 2015
                                      • 26
                                      Never mind Hamie,
                                      Im an idiot and unplugged the wrong cable... Luckily the unit didnt power up when I jumped the two lol...
                                      UPDATE:
                                      After jumping the R51/52 together while P31 was unplugged I DID GET THE TEST PATTERNS! Looks like im sourcing a MAINBOARD!
                                      • LGinMD
                                        • Oct 2015
                                        • 26
                                        Only question is, which one is the "Main Board"? Its the board with all of the inputs on it correct? If not then I take it its the board in the center that has P31 on it?
                                        Thanks again all!
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Yanleb
                                          Schematic or datasheet for Plasma TV buffer chip
                                          by Yanleb
                                          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                          05-18-2022, 01:36 PM
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
