vizio m3d650sv Found the problem need TAB advice
  • michaelgrepp
    • Oct 2015
    • 6
    Hey Guys,
    Been looking around this forum a lot and people have been super helpful, well I totally figured out HOW to fix this tv, after disassembly I found out it was the Tab Bonds, two to be exact, with specific and exact pressure I can get all the lines to go away along with image blurring, I'm just wondering what advice people have for where to get thermal padding and how to attach it etc..
    Thanks again everyone!
    -Michael
  • steves7839
    • Nov 2014
    • 200
    Re: vizio m3d650sv Found the problem need TAB advice
    Search posts on the term "tab bonds" and there will be a lot of information. I'm attempting a similar repair on a Sony 52", a bit hard to handle.
    • rajbot
      No Power problem with Vizio E60-E3
      by rajbot
      Hi all:
      I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
      I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
      On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
      03-22-2023, 08:09 AM
    • Jidis
      Need T-Con Advice (Vizio P602ui-B3)
      by Jidis
      I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
      He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
      09-22-2025, 05:10 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Pinky Deepak
      Vizio M60-C3 Left Edge problem
      by Pinky Deepak
      I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
      Here's a video of both the issues: https://youtu.be/hMqc760nB3o
      09-27-2024, 05:11 PM
