Samsung PN59D6500 - Common fault - Power cycling
  • gravesent
    • Oct 2015
    • 11
    Good morning,
    Is anyone familiar with this issue? I have a bad main, 100% confirmed. TV cycles on and off, does not respond to remote function at all. I was wondering if there was any way to enter the service mode bypassing the mains operation of boot? I am unable to enter service menu (Mute-1-8-2-Pwr), the set only cycles, displays input banner then turns off, then back on, however the LED does indicate that there is IR activity as it is flashing. Is there a way to initiate the firmware update without being in the tvs menu? Any help is greatly appreciated.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PN59D6500 - Common fault - Power cycling
    How can you be 100% sure have you checked any voltages ?
    • gravesent
      • Oct 2015
      • 11
      Yes. TV stays on with ps_on jumped and logic test patterns displayed. This isn't my first repair.
      • gravesent
        • Oct 2015
        • 11
        I just figured this main boards NLA, no repair kits, didn't know if anyone had found a way around this issue or any specific components on the main board that they have found to be at fault.
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
