Samsung PS50B530S2W
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Samsung PS50B530S2W
    The relay, if it is, keeps getting damaged when tv in on for few minutes. As if high current is going to it. See pictures:
    I have bought a new board, worked for 20mins then the same issue as old board (in pics).
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Re: Samsung PS50B530S2W
    Any one can help me out??
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Thats not a relay its a Polly cap think for the Vs voltage probably means Vs fets are short. Do you have a DMM and do you know how to check for Short Circuit ?
        Did you replace that capacitor?
        You may not have used the proper pulse DC rated cap. It is important that you don't just use an X-cap from a power supply, or otherwise.
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Thanks for the reply! I have not changed anything. I have two boards: the original with same part burnt. Ordered a used board from ebay, it worked for few minutes then after it cuts out. Looking the board, it has the same as original. Is the transformer causing it?
          • speedypro
            • Feb 2013
            • 561
            • United Kingdom
            Looking at the schematics, the burnt cap is: 68nF / 1250V
              That cap does go bad on some of these sets. I would try replacing it. Use an SMPS high pulse DC rated polyester capacitor.
              • speedypro
                • Feb 2013
                • 561
                • United Kingdom
                I can only this from the UK: http://www.chsinteractive.co.uk/elec...-rm-37-5mm.htm
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  I had it on a Ps50c450 where Vs fets were short. Were blowing that cap. Check them before blowing another cap.
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    Yes I have found the shorted fet: EN210A. Need to find a UK supplier.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Yeah thats probably whats killing that cap have you also checked the gate driver circuit ?
                      • flocko
                        • Nov 2012
                        • 1121
                        The EN210A is a 100v 10A TO-220 schottky diode full part number FMEN210A should have no problem finding them digi-key list them so would RS I think
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          Ok I have replace the FET with a new one we've got, resoldered the 'almost damaged cap' but it still burns on that same pin. Done few research as I feel as though those caps can 'age'.
                          I'll wait for the new cap and report back if same problem.
                          Thanks.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            What do you mean almost damaged ?
                            • speedypro
                              • Feb 2013
                              • 561
                              • United Kingdom
                              Those pictures are of the first board. The second board, bought off ebay, the cap pin burnt only to cause 'cold solder'.
                              • speedypro
                                • Feb 2013
                                • 561
                                • United Kingdom
                                I have replaced the polly cap and all seems ok. But I know the tv works.
                                I've used my heat glue gun to fit it nicely.
                                  09-07-2024, 05:50 AM
                                • Journey11
                                  Samsung TV won't turn on ... keeps cycling the power relay on & off
                                  by Journey11
                                  Hi All,
                                  First time posting here ... my name is Kevin but my friends call me Journey.
                                  I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                  After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                  It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                  07-04-2024, 02:44 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
