Samsung sp-r4232 not working
  • e.zog
    • Apr 2015
    • mexico
    Hi there.
    I´m trying to repair an old plasma model: samsung sp-r4232.
    The tv doesn´t turn on when i press the power button, but when i plug the set into the wall outlet I can see faint snow in the picture,
    the screen is faintly glowing.
    yesterday i took the back cover off but everything seems fine, no bad caps, I have tested voltages VS and Va.
    the va was 68v. I adjusted it to 70v, the vs seems to be what it is supposed to be.
    is this a mainboard/logicboard problem?
    Thanks in advance
  • DynaxSC
    ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
    by DynaxSC
    I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
    Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
    Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
    The behaviour is also really very strange, i.e.:
    • The disk shows always up in BIOS - so it is recognized, so far so good
    • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
    02-23-2025, 01:33 PM
  • nader_guesmi
    Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
    by nader_guesmi
    Hey everyone,
    I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
    Problem: The CI+ module doesn’t read the Digi card.
    I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
    • CI+ production keys: Success
    • ECP keys: Not installed
    So the TV doesn’t even attempt to communicate with the CAM/card.
    I’ve tried multiple Digi cards (both old and new), and they work fine on another...
    09-09-2025, 03:04 PM
    09-07-2024, 05:50 AM
  • giulio93
    Samsung S21 FE wifi not working
    by giulio93
    Hi everyone, I have a Samsung S21 FE with no wifi. I can't see the classic antenna cable so i suppose it is integrated in the circuit of the mobo. Can anyone help me with this?
    I have very good skills in soldering and stuffs.
    01-08-2025, 11:55 AM
  • Carlcox89
    Samsung ue49mu6225k intermitent working
    by Carlcox89
    Hello all,
    I have a friend's Samsung UE49MU6225K with bn41-02568b that is working intermittently. ie. sometimes i have standby light and can power on, sometimes no standby light and cannot turn on.
    I have checked that disconnecting main board BN-41 from the power supply, the voltages are good and panel light comes on. So i guess it's the flash corruption bug present in this MU models, right ? However, i cant understand how it is able to fix it by itself sometimes?!
    After some fiddling with a bus pirate i was able to dump the flash.
    Could someone tell me if it's indeed flash...
    12-20-2023, 08:10 AM
