Need help ID'ing these caps please..
  • kevinm34232
    • May 2012
    • 1884
    In the photo they are C203 and C204. Can anyone tell me what these are, or what substitutes I can use for these please?
  • mariushm
    • May 2011
    • 3799
    Re: Need help ID'ing these caps please..
    They're capacitors made by Samyoung , 270uF and 10v. I don't see the series on their website, it's either discontinued or a custom order for a large manufacturer (so exact specifications unknown).
    You can replace it with any polymer capacitor with a value of 270uF and a voltage rating of 10v or higher (16v for example)
    • kevinm34232
      • May 2012
      • 1884
      Thx very much! Is it common for these to short out, as both shorted when I was forcing power supply to turn on, and I touched the 24V pin next to the 3.5V supply by mistake?
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
