Panasonic TC-P50G25 4 Blinks
  • cdthomas23
    • Aug 2015
    • 8
    Okay, I have perused through several threads on this. I have also done troubleshooting with the 2010_FHD_Plasma_TV_G20_G25_Series_Troubleshooting_Handbook.
    I was originally getting 10 blinks, but now it is consistently 4. I troubleshot the Vsus, P15, and Vda. Vsus and P15 look great and always show resistance of >1.5 kohms. Vda actually bounces around a bit, but shows even in the M ohms range. I thought that might be my problem.
    I even ordered a new P board, but it shows the same type readings, and it did not fix the problem. So I continued the 4 blink troubleshooting in the flowchart.
    • I disconnected SC20, plugged in, powered on. Still shows 4 blinks (not 6 for SC board)
    • So then I measure voltage at Pin 9 of P7 when turning on, and it shows 3V.
    So the flowchart would tell me it is the P board, but I know that is not the case. Please help or let me know what I am doing wrong. Thanks!
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G25 4 Blinks
    Ok, problem is SC2 shorted(most likely). disconnect that and you should find 4 blink clears.
    if you look at page 6, shows 4 blink SC is primary suspect , then P, but P board failure, rare, yet to read of one in this forum.
    P26, again states SC as first choice
    Unfortunately a resistance of 1k or more does not necessarily mean no short since there is 200v on that SC2. At SC2 resistance can be 300k up into megohms and even then does not guarantee SC is not faulty but a 4 blink usually means the resistance is too low on the Vsus
    10blink / 4 blink just about can be sure is the SC in this model
    make sure you do the Sd/Su buffer board resistance checks in that guide and report back readings. they can short out too and if they are you will blow a new SC board if gone unchecked.
    • cdthomas23
      • Aug 2015
      • 8
      Thanks, TW. I will try removing SC2 tonight to see if blinks go away. For the Sd/Su checks, do I just need to check the steps on 43-44? I can report that back this evening as well.
      • tw2005
        • Oct 2011
        • 6458
        Not on my normal PC, damn thing has been hit with malware. There's a section which shows resistance checks in a table and some pics of the points to check like Vfo etc. need a meter that can autorange or get to about 6 megohm.
        The buffers generally survive but must be checked
        On the SC Q661 always shorts if it has failed, plus a whole lot of other parts
        The 4 blinks should go but it'll still error, maybe 6 or 7 blink. You just want to see a change from 4.
        • cdthomas23
          • Aug 2015
          • 8
          Thanks again. Here's what I see. My multimeter only goes to 3.999 Megaohms
          1. Unplugged SC2, power on TV, 7 blinks, so that looks promising.
          2. Followed instructions for resistance testing of SU-SD boards (P. 43-44). Removed connectors and screws.
          - TPSU15: 1.285 M ohms (lower than sheet says)
          - TPSU16: 219.4 K ohms
          - TPSU17: 3.999+ M ohms (still rising to top of range of meter, so that one is probably good)
          - TPSD26: 3.999+ M ohms (still rising to top of range of meter, so that one is probably good)
          - TPSD28: 219.8 K ohms
          - TPSD29: 1.258 M ohms (lower than sheet, but similar to TPSU15)
          Should I get a new SC board or do you see other issues? Thanks.
          • tw2005
            • Oct 2011
            • 6458
            because the readings are consistent on both boards and not short or low ohms I'll say they're fine. I don't know the TP numbers but I assume the 1.285M is Vfo? whnever the buffers go, just about guarantee Vfo will be short or a few ohms. If you reversed the probes around you may get a different result closer but not the first time we've different readings depending on brand of meter.
            http://www.moduslinkptstvboards.com/TXNSC1LPUU/
            not as cheap as i was hoping, if you're a whiz with the soldering iron you may be able to self repair but I lost count of the people who have tried and failed but I've got these down pat now.
            I think you'll have rev AF , but Rev AP would work in this TV too and AW if you can get lucky to find but lack of supply means high prices now. May no longer be available new from Panny
            Moduslink are reliable though
            New SC, hook everything up right and it should be a runner again
            • cdthomas23
              • Aug 2015
              • 8
              I am not very handy with soldering, so I am not even making that an option.
              Looks like that one is Out of Stock. Panasonic (through Encompass) has one for $170. I also found one (from the same place I erroneously purchased the P board) on Sears Marketplace from TVReplacementParts for $160. I will probably see if they will swap out what I got for that one and just go with it.
              Anything to be aware of when hooking it up? Just make sure power is out of TV, install, and test?
              • tw2005
                • Oct 2011
                • 6458
                no, just the common sense stuff. check all cabling , make sure ALL earthing bolts are in. Mistakes i read about are either a cable is left off somewhere with all the fiddling, bolts left out of the sd/su (not good)
                Trickiest part will be getting the panel ribbons in all the way and straight. often you end up with horizontal lines. If you do the lines will line up with the corresponding connector. just don't have the Tv on when re-aligning these. some have tried that and Poof shorted buffer, blown Sc.
                Those boards , if they're not new but rebuilt, Modus is a cheaper option but your choice. they will repair yours and ship back.
                • tw2005
                  • Oct 2011
                  • 6458
                  That sears site, wonder if it's sears or like an Ebay. someone else selling it , probably used. does not tell you much at all. what's the wty?
                  TVReplacementparts Return Policy
                  This Marketplace seller does not have a custom return policy. The sears.com return policy will apply to this seller's products.
                  http://www.tvserviceparts.com/TXNSC1LPUU.html
                  • tw2005
                    • Oct 2011
                    • 6458
                    people are starting to wake up and sell these broken. There were 3 or 4 on Ebay but all gone, snapped up by someone who repairs them I'd say. Could get 30 bucks that way.
                    Don't see much point though. If they're not available new, and they are asking for the cores then they are being rebuilt in which case why not get yours rebuilt and save $60?
                    • cdthomas23
                      • Aug 2015
                      • 8
                      Certainly saw that myself. It seems to be a Marketplace similar to Amazaon. The P-board I bought clearly said it was New. This one, not so much. So, if I can return the P-board, I will probably just buy this one for $10 more from Encompass. They all seem to want the core back, however. Encompass even charges a core fee until you return it.
                      • tw2005
                        • Oct 2011
                        • 6458
                        sounds like you have a plan. Hope it works out but once you get a good SC, should be ok. I would check Sc2 and Q661 for shorts as a quick check before you install it just in case you get a dud.
                        • cdthomas23
                          • Aug 2015
                          • 8
                          Will do. Where is Q661 located? Tried to look last night, but I did not find it. Thanks again for the help. I will follow up when I get a new board.
                          • tw2005
                            • Oct 2011
                            • 6458
                            on a heatsink of 2 transistors near SC50 connector. Always fails when these boards go from what I see.
                            • cdthomas23
                              • Aug 2015
                              • 8
                              That did the trick. Hopefully it holds for awhile. Thanks again for all the help!
                              • cowboy-daddy
                                • Dec 2013
                                • 3
                                Does anyone still watch this post for questions? I'd really appreciate some help with my TV.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  all you have to do is post up the question? But based on your message to my email, 4 red light that changes to 7 when I unplug the SC board.
                                  Would be the SC board failure. So you can serach TNPA5081 rebuild and get heaps of info or send it to PTS Moduslink or even a bunch of Ebay rebuilders or try yourself but there will be some small SMD work involved
                                  • cowboy-daddy
                                    • Dec 2013
                                    • 3
                                    Thanks, I didn't want to repost a question already answered.
                                    I'll try the search and see what I can come up with. Didn't know if there was a pretty standard list of components to replace for this issue.
                                    • cowboy-daddy
                                      • Dec 2013
                                      • 3
                                      Ok, I am getting soooo lost. I think at this point I either just want to get a new board or send mine in to get repaired. I can do the work and replace the parts, but I simply do not have the time to do all the troubleshooting or guesswork. I've tried the Moduslink links that I've found in a few threads and all the bring me to is a glorified search engine. Can someone post specific links either to get my board repaired or where I can buy a refurbished one? Or does someone on here repair boards and I can send them my board?
                                      Thanks.
                                      • jetadm123
                                        • 2169
                                        The company is now called PTS Electronics. The link below should help:
                                        http://www.ptselectronicsinc.com/txnsc1lvuu/
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
                                        • nobbnobb1
                                          Panasonic TC-P50U50 Powers Off - 8 blinks
                                          by nobbnobb1
                                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                          2x DG302 (Q16051)
                                          2x RF2001 (D16041)
                                          2x 5.6 ohm SMD resistor
                                          1x BD8694 IC
                                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                          03-21-2023, 08:33 PM
