Hisense 50" Led
  • dbier63
    • Aug 2015
    • 157
    • usa
    Hisense 50" Led
    Hisense 50K360 G I am still getting a flashing code before led's power on. Blinks 7 times and a very short pause then 3 more blinks. Then the power supply turns on the led array. Can anyone tell me what this code string relates to? Could it mean the problem is with the panel?
    I've changed main and tcon boards
    Thanks in advance
    Dan
  • chris89
    How to fix Hisense 43A6H 4k Google TV - 10 Blinks?
    by chris89
    Hi I replaced the mainboard, the t-con, and wifi, still no dice.
    Any idea on what it could be, causing the tv to not turn on? Just blinking LED light.
    Processor gets hot so I know the Mediatek MT9612 is functional.
    03-15-2025, 06:46 PM
  • Donny2derby
    Hisense 43A7100FTUK 2/3 red blinks.
    by Donny2derby
    Hi again all.
    Have got this set and trying to trouble shoot the above issue. I'm not sure if it's giving 2 or 3 standby blinks as one of them appears to be a very quick double blink.
    The screen remains dead at all time. My fault finding so far has led me to what I believe is the barrier diode marked MBR B102 00CT. Which has two opposing diodes marked on it. And my meter is reading a dead short both ways when connected onto the board.
    The reason I'm thinking this could be at fault is that everything up to there on the hot side tests and measures ok....
    10-22-2023, 04:46 AM
  • Biruslapio
    Panasonic P58V11B 8 and 12 blinks error "fix"
    by Biruslapio
    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
    04-13-2021, 07:13 AM
  • Coolgoodman
    Faulty Hisense 85Q6NAU TV
    by Coolgoodman
    85” Hisense TV
    Greetings,
    Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
    Dear TV technicians of forum, I hope this message finds you well.
    I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
    I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
    07-24-2025, 03:02 AM
  • ShahZaib Ghumman
    Can I Swap Screens Between Two Hisense 75” QLED TVs?
    by ShahZaib Ghumman
    Hey folks,
    I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
    A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
    So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
    03-25-2025, 10:59 PM
