samsung le40a536t1f no power red led blinking 5 times
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Hello all and sorry for my english!
    I took this samsung tv from my friend. Firstly the red led flashes consecutively and the tv don't turn on. He changed all the electrolytics from psu and one of the rectifiers on the secondary and now the red led blinking 5 times and then off. Also he found a bad smd capacitor on the mainboard which was burned but he didn't replaced the cap because he didn't find. With all connectors connect we have no voltages on psu.
    firstl i would to ask if threre is a way to test the psu out of the connectors. I saw in another thread and i connect the ps-on pin with gnd and i have the 5.1V standbay voltage but there isn't other voltages. Should i do something else to do tha test?
    thanks in advance!
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Re: samsung le40a536t1f no power red led blinking 5 times
    this is the powers supply schemtaic
    • Hamie
      • Apr 2014
      • 1383
      Jump on the power supply with the mainboard Disconnected.
      Jump 5.1v standby to ps-on
      And also jump 5.1v to inverter on/off
      • vagos_89
        • Apr 2014
        • 61
        • Greece
        Thanks for your reply. I did exactly tha you said and i have tha standby voltage 5.1V but i dont have the other voltages. In pins for 5.1V i have 2,2V and in pin fro 13V i have 0,6V. thid mean bad power supply, right?
        As i said all electrolytics and one rectifier in the secondary replaced. All diodes, rectifiers and mosfets of the board are good. Any advice to continue??
        Thanks!
        • vagos_89
          • Apr 2014
          • 61
          • Greece
          Ok i did a mistake with the counting of pins and i connected wrong. Now i dit it right and i have the 5,1V and 12,6V but When i connect the power supply to the mainboard i have no voltages. Is there something that can i test to the mainboard before i start to search for another on?
          Thanks!
            09-07-2024, 05:50 AM
          • ahmarzo
            Hp 15-cs laptop 5 times dc jack blinking white
            by ahmarzo
            I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
            First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
            Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
            But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
            12-28-2024, 04:46 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • YasaCh
            Sony kdl 40p5500 red light keeps blinking 3 times
            by YasaCh
            Hello...
            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
            i opened the back cover no sign of damage on the powery suply or motherboard
            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
            07-07-2025, 11:53 AM
            09-06-2024, 11:40 PM
