clicking plasma
  • overkill
    • Jul 2015
    • 6
    clicking plasma
    I had a hell of a storm come through the other night. Lost power for just a moment. I then noticed that my plasma would not power up. I checked my Panamax surge protector, but it was showing no failures. I was told that it was possible that it surged through the hdmi. I unplugged it for an hour and powered it back up. It (samsung pn58c7000yf) just clicks every few seconds. I took the back off and attempted to unplug each board as instructed in other post. The red indicator light remains lit but the clicking persist.
  • tw2005
    • Oct 2011
    • 6458
    Re: clicking plasma
    maybe see if you can find a procedure to isolated the main, jumper the PSU and on the logic board there may be a jumper which forces the test patterns on. Basically under this, if everything is jumpered correctly the TV should fire up and produce test patterns on the screen. In that case the mainboard would be the issue.
    I just don't know it off the top of my head but it's a standard procedure used in the Samsungs.
    • overkill
      • Jul 2015
      • 6
      Re: clicking plasma
      Thank you very much. I will try to find that procedure
      • overkill
        • Jul 2015
        • 6
        Re: clicking plasma
        Having trouble finding a test procedure. Anyone have any input on where to find the test procedure or any other suggestions
        • Hamie
          • Apr 2014
          • 1383
          Re: clicking plasma
          It's probably the mainboard so you'll need to jump on the powersupply.
          Jump ps-on to ground. And 5vstnby to vs-on.
          Then on the control board jump pins 3-4 on the little black square with 4 pins on it
          Located just above the arrow here:
          Then disconnect the orange wire leading to the main board.
          Power on the TV.
          • bffargo
            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
            by bffargo
            LG 60PB66550 NOV 2014
            PSU: EAY63168603
            PCB: EAX65359531 2013.11.01 Rev:1.0
            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
            Symptom:
            While watching, just went black and started clicking relay every few seconds.
            Initial diagnosis:
            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
            Deeper diagnosis:
            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
            09-09-2022, 07:34 PM
          • Sisko
            Onkyo-593 No power and now clicking sound
            by Sisko
            Hi all!!
            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
            10-03-2025, 02:18 PM
          • B0r1s
            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
            by B0r1s
            PSU - BN44-00878A
            Symptoms:
            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
            A weak clicking sound was coming from the transformer.
            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
            Progress:
            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
            01-17-2023, 04:58 PM
          • novak2
            Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
            by novak2
            Hello there,
            I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
            The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
            From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
            Thanks in advance.
            09-25-2020, 02:34 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
