Problem with Samsung TV after Factory Reset!!!!
  • bobsana666
    • Jul 2015
    • 9
    • Bulgaria
    Hello everyone!!
    My problem is with TV-Samsung LE37A686M1F.
    I make a factory reset of my tv and all it's over for me
    making short circuit of my eeprom (at least I think that's it's my eeprom) but nothing changes.
    Please Help me to fount a problem and repair it!!
    several pictures
    https://drive.google.com/folderview?...nM&usp=sharing
    Regards!!!
  • Hamie
    • Apr 2014
    • 1383
    Re: Problem with Samsung TV after Factory Reset!!!!
    What's the board number?
    You sure that's the EEPROM? what's the chip called?
    How long are you shorting the pins together? It should only be for one second as soon as power is applied to the TV.
    • bobsana666
      • Jul 2015
      • 9
      • Bulgaria
      The main board number is BN40-00120A
      I am not sure that's a EEPROM - number of chip(IC5107) , i shorting a pins maybe 3 second and cut the wire.
      • Hamie
        • Apr 2014
        • 1383
        That is the EEPROM,
        trial and error, literally plug the TV and instantly remove the short. It's quicker just to stand the board on its side and use a small flat screwdriver.
        3 seconds it probably too long.
        • bobsana666
          • Jul 2015
          • 9
          • Bulgaria
          That is the EEPROM,
          Tomorrow I'll try again as you say 1 second, because TV is in my office i cannot try it now
          i hope to have result
          • vinceroger69
            • Mar 2012
            • 6714
            Maybe of some help?
            http://wiki.samygo.tv/index.php5?tit...y_EEPROM_Reset
            • bobsana666
              • Jul 2015
              • 9
              • Bulgaria
              Hello guys !!
              The problem are resolved by reset a EEPROM, but the problem that prompted me to factory reset are still there at my screen .... Any ideas ??
              • vinceroger69
                • Mar 2012
                • 6714
                so whats the original problems the green and white bands?
                • bobsana666
                  • Jul 2015
                  • 9
                  • Bulgaria
                  yes
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    is the band in the picture just on the one side or both?
                    • bobsana666
                      • Jul 2015
                      • 9
                      • Bulgaria
                      only left side
                        Most likely, that is a bad LCD panel. Unfortunately it will not be repairable if that is the case.
                        • bobsana666
                          • Jul 2015
                          • 9
                          • Bulgaria
                          mhm clear.
                          the problem is not tooo bad after 20 min maybe they are almost invisible..
                          big problem it was after factory reset when the picture are lost...
                          thanks to all
                          and yet if someone has something in mind, lets write
                          : Popcorn2:
                            09-07-2024, 05:50 AM
                          • howardc64
                            Samsung UN55JU650DF network/streaming problem
                            by howardc64
                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                            07-09-2025, 12:44 PM
                          • alro7779
                            Samsung UN55MU6103F video problem; has colored stripes on the display
                            by alro7779
                            Hello, everyone!
                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                            09-27-2025, 11:29 PM
                            09-06-2024, 11:40 PM
