Samsung PN51D550C1F Plasma Samsung Logo Boot Loop
  • sfernandes
    • Oct 2013
    • 229
    When I plug the set in I get the Samsung logo then the screen turns off and back on again displaying the logo again it does this over and over in a loop. The set does not respond to remote or front button commands. While this is happening I have tested the VS and VA and its steady even though the panel appears to turn off the logic board keeps blinking the regular heart beat.
    Any ideas?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung PN51D550C1F Plasma Samsung Logo Boot Loop
    Short out pins 3 and 4 located here on your control board.
    Disconnect the LVDS cable that connects the mainboard to the control board .
    You should get test patterns, if they display as normal then you have a faulty mainboard.
    • sfernandes
      • Oct 2013
      • 229
      Ordered a new main and installed it and it fixed the issue.
      Thank You for your help.
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • giova96
        samsung qe55q60rat logo loop
        by giova96
        Good morning
        I have this Samsung which has the typical display problem, basically I see the initial Samsung logo for a few moments and then restarts
        I have the audio from the antenna present, by disconnecting a flat panel from the display the TV remains on with the audio of the program present, but everything on the screen is black (backlighting present)
        I know that there are steps to save it by performing operations on the panel card
        Does anyone have a more detailed guide? given that this is already the 4th TV that this has happened to me and it seems like a fairly well-known...
        03-06-2024, 03:30 AM
        09-07-2024, 05:50 AM
      • eigma
        Samsung UN40H5003 boot loop every ~8 seconds
        by eigma
        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
        Main board: BN94-07592P / BN97-08922R...
        11-20-2024, 10:31 PM
        09-06-2024, 11:40 PM
