Samsung 46mx-3 will not start (model: lh46bplbc/en)
  • asko79
    • May 2011
    • 21
    • Bosnia and Herzegovina
    Samsung 460mx-3 will not start
    main board is bn9404046a
    Power is BN44-00310A
    all voltages are fine except for the PS, which is 0.79 V
    I need a service manual for the PSU and the value of the resistor R008 to the inverter ss1460-12a01 rev. (I tried to turn on the inverter bringing together the SB and BL.ON across the resistor and make the connection and so we hurt resistor R008 even though the device was turned off)
    I tried to connect the SB and PS across the resistor and the relay is switched on is not excluded
    I wonder if the detector voltage 5V (lamp error comes from the main board or the inverter)?
    I suspect that by the main board
    Thanks in advance.
  • asko79
    • May 2011
    • 21
    Re: Samsung 46mx-3 will not start (model: lh46bplbc/en)
    does anyone have a datasheet of ic ss1091sn
      09-07-2024, 05:50 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • JSin21
      Compatibility of main boards between different variations of samsung MU6100
      by JSin21
      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
      I have Samsung Smart TV UA65MU6100WXXY version DA01
      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
      11-27-2023, 04:54 AM
    • mrautom8
      Samsung TV UN75H6350AFXZC main board schematics?
      by mrautom8
      Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
      Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
      While relay is on, all voltage rails are present and steady (scoped) on main board.
      I love a good logic puzzle but getting lost without any schematics.
      No shorts on ANY capacitor main board.
      Thermal camera shows 3.3V inductor getting warm instantly but...
      10-19-2025, 06:32 PM
    • Yanleb
      Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
      by Yanleb
      Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
      If they are not compatible why did Samsung give them the same part number to begin with?
      08-04-2025, 11:35 PM
