LG 50PZ570 Plasma
  • putz182
    • May 2015
    • 9
    • Brazil
    LG 50PZ570 Plasma
    after 3 years my plasma TV is gone. I started some digging before send it to repair, even before I know that it I will come back to me.
    The technicians just want to replace every single board in my TV. I can not see the point so I start the quest to fix it myself.
    First the symptoms.
    It started with RCA, sometimes the image was gone but with sound, the power cycle fix it, or even changing TV source. So far so good.
    After, HDMI faced solarized picture (negative picture like). Power cycle was handle it. Strange it may sound, the menu had perfect colors.
    At least, no image more. When I power I can see the plasma trying to lighting but going dark after.
    The power source is ok.
    The Y-sus is doing a smooth buzz noise.
    Soon the tv enter in error mode the noise is different
    I bought a new Y-sus, mounted it and worked fine for 10 minutes and again, the image is gone.
    I asked for a EBR69839001 Y-sus and the seller send me EBR69839002. They were identical.
    Some people told me to change Y-sus and Z-sus, but I read in this forum a person who made that and lost the two boards.
    Well, I tested every cap with multimeter and the board shorts. Nothing found.
    I can also identify a blinking error pattern in the T-con, but couldn't find the service manual.
    I tried to remove the LVDS cable to check some picture or image and nothing.
    Checked the buffers as well and nothing.
    I have a scope and want to check with it, but I really need some guidance now. I did the basic which was possible with some reading. Now I need to get mad.
    Please, anyone?
  • sordids999
    • May 2013
    • 2161
    Re: LG 50PZ570 Plasma
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • tw2005
      • Oct 2011
      • 6458
      I'm thinking it's a mainboard issue. Those ysus are not identical but very similar, running change with panels I'd say,
      EBR69839002 = PDP50R30111,
      EBR69839001 = PDP50R30000
      • putz182
        • May 2015
        • 9
        • Brazil
        Check the TV pictures.
        I can not explain why, but I do agree. I think it is the main board.
        Can I look for the problem myself or it is better just replace it?
        I want to be sure.
        I will read the service manual. Thank you.
        Any other suggestions are welcome.
        • putz182
          • May 2015
          • 9
          • Brazil
          Just went through Y-sus and Z-sus test, Check the results:
          I need the experts now. Does it really means that there is a failure?
          I also checked the Vsc on Y-sus B/D, but it unreadable. It is oscillating a lot.
          I will pick a 100x probe and post the wave as well.
            Readings look ok to me - if the devices were failed they'd read shorted. That's just a small variation on the spec.
            • tw2005
              • Oct 2011
              • 6458
              there's nothing there that i see as an issue.
              • putz182
                • May 2015
                • 9
                • Brazil
                What is making the Vsc oscillating then?
                I can not make a clear reading?
                Wouldn't that be a Fet problem?
                  Maybe - but since you've found no shorted FETs, probably not.
                  Did you try checking without buffers installed?
                  • putz182
                    • May 2015
                    • 9
                    • Brazil
                    I tried, I disconnected the buffer board and power the TV. Guess what?
                    Just got a visible spark coming from the PSU.
                    What the hell a did wrong?
                    Tried to power on, but no life at all. Power on and off after...
                    Now what? Can I fix it to?
                    • tw2005
                      • Oct 2011
                      • 6458
                      In the PK series guide it states do not run the TV with the buffers disconnected. I suspect it's probably the same for this series too.
                      further into the guide it says
                      "Remove the Y-Drive
                      boards completely if these
                      connectors are removed or the
                      boards will fail."
                      further still,
                      "WARNING: The upper Y-DRIVE Board has to be
                      Removed Completely if
                      P117 is pulled."
                      "WARNING: The lower
                      P118 is pulled."
                      So if the connectors were disconnected but buffers still bolted in not sure of the final outcome but drive boards and ysus may now be fried.
                      so I'd check the buffers frst and see if shorted, if ok try the other ysus you have since i don't think it's the sustains but mainboard for the original fault
                      • putz182
                        • May 2015
                        • 9
                        • Brazil
                        Really sad...
                        I checked for shorts and none were found in the buffers, but I did tried as tom suggested. Not good idea.
                        I live in Brazil and I'm having lot of difficulties to find the boards here. Do you guys know a provider that I can import?
                        If it is the main board, how to explain Vs oscillating?
                        • putz182
                          • May 2015
                          • 9
                          • Brazil
                          Updates!
                          I checked and the Z-sus is gone!
                          I also checked the T-con and is ok.
                          Buffers ok.
                          Y-sus ok
                          PSU ok
                          Is there any way I can repair the main board?
                          • putz182
                            • May 2015
                            • 9
                            • Brazil
                            Please, really need some help!
                            Replaced the main and Z-sus.
                            I now have some flickering image, but no image.
                            I can hear a loud buzz noise coming from Y-sus.
                            Looked over for another board without sucess.
                            Any one?
                              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:20 PM
                            • Jaime Morillo
                              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                              by Jaime Morillo
                              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                              The TV was stuck on the logo and I couldn't access the update menu.
                              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                              The image result was good, but the image is inverted.
                              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                              08-18-2025, 11:38 AM
                            • piershs
                              Toshiba plasma 50WP16 wierd double image fault
                              by piershs
                              My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                              Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                              • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                              • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                              08-01-2020, 01:07 PM
                              HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              09-06-2024, 10:56 AM
                              HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                              This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
