order to put films layers back together on screen
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Took 47 in lg led smart TV apart to change the Leds and lost order of which way the films go on. There's 2 white prices. Then the silver film then the thick plastic piece. Also my cousin ended up cracking that plastic piece. Is this thing important or can I use something else in its place. I fixed the LEDs just don't know the order to put this back together thanks
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: order to put films layers back together on screen
    With a philips LCD i know that the plastic part goes first and then the 2 thin layers , might be different for LED and yes that plastic part is important. If you install it with the cracks in it you will see if on the screen.
      The plastic piece is a prism guide plate, it boosts the light output of the panel and makes the light more directional. Without it, the light output will be lower, you will probably see LEDs in the image, and colours may be distorted (depending on the panel.) So you do need that plate there. You will have to source another one.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        What about the silver film? Is that last then closer to the screen? Or closer to the LEDs? Also could I use any type of plastic clear?
          The plastic is optically clear stuff. So no ordinary stuff. It also gets hot and cannot warp, burn or emit bad smell next to 60C LEDs.
          You need to be more careful next time. Take it as a lesson!
          • mattstolte
            • Dec 2013
            • 612
            • usa
            Originally posted by tom66
            the plastic is optically clear stuff. So no ordinary stuff. It also gets hot and cannot warp, burn or emit bad smell next to 60c leds.
            wasnt me. My uncle was down in my shop moving stuff and cracked it, do u know of anything i can use?
              You might be able to find something that fits from a similar screen. But there aren't any readily available components as far as I'm aware. I know because I've looked into replacing water damaged films before. I found one supplier in China but they needed original CAD drawings and had a minimum order of 50 sheets. Over $350. Yeah, not happening.
              • mattstolte
                • Dec 2013
                • 612
                • usa
                I just need the hard plastic piece was wondering if I could another sort of plastic if it was clear and didn't warp
                  It has special optical properties and also forms as a mechanical support for some of the BLU layers so I would say no.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I wanted to ask this question myself.
                    Do you think Tom, that these thin layers can be flipped over when you re-install them?
                    Or they can be installed only in one way(direction)? They are directional(like tires(tyres)?
                    The two-three thin sheets, are the same, or they are differences between them?
                      The prism film is directional. The other films are diffusers or guide plates and do not have directional properties.
                      You can identify the prism film because it is highly reflective on one side and has a kind of scan-line pattern to it.
                      More info on LCD backlight:
                      https://www.youtube.com/watch?v=jiejNAUwcQ8
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                        This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-12-2024, 02:30 PM
                        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                        HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 08:10 PM
                        HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
