Samsung UN46D8000 dead - No led/backlight
  • felipevieira
    • Mar 2015
    • 7
    • Brasil
    Hi!
    I have my TV since 2012. Today it is not turning on. No led, no backlight, nothing.
    I opened searching for blown fuse, but it is ok.
    If I try measures voltage in CN201 with the P28 cable connected in the main board I got all pins with 0V but the 4th pin is 5.32V. But if I disconect the P28 cable, the backlight comes on and I got the following measures in P28 Cable:
    Pin 1 - 5.30V (B5V_PW)
    Pin 2 - 3.33V (SW_POWER_OUT)
    Pin 3 - 5.32V (B5V_PW)
    Pin 4 - 5.32V (A5V_PW)
    Pin 5 - 0V (GND)
    Pin 6 - 0V (GND)
    Pin 7 - 12.77V (B18VS_PW)
    Pin 8 - 0V (GND)
    Pin 9 - 12.77V (B18VS_PW)
    Pin 10 - 4.67V (SW_INVERTER)
    Pin 11 - 12.77V (B13V_PW)
    Pin 12 - 12.77V (B13V_PW)
    Pin 13 - 12.77V (B13V_PW)
    Pin 14 - 3.03V (PWM1_DIM_OUT)
    Pin 15 - 0V (GND)
    Pin 16 - 3.02V (PWM2_DIM_OUT)
    Pin 17 - 5.02V (OVD_ON_OFF)
    Pin 18 - 3.03V (PWM3_DIM_OUT)
    Pin 19 - 5.20V (OVD_LEVEL)
    Pin 20 - 3.02V (PWM4_DIM_OUT)
    If I follow the chart from Service Manual, I need to replace the main board. But I need a second opinion if it is possible.
    Link to Service Manual
    Warning: The image is in high resolution (~3.5MB each).
    Thank you for the help!
    Last edited by felipevieira; 03-22-2015, 09:42 PM. Reason: Added the warning information
    Re: Samsung UN46D8000 dead - No led/backlight
    It is correct that when you remove the cables between the power supply board and the main board you do get backlights then it means the main board is the problem.
    When you connect the cable back in, check pin 2, if it is <1V then the main board is not sending the PS-ON signal.
    • felipevieira
      • Mar 2015
      • 7
      • Brasil
      Thank you for the reply.
      Hummm I think the best way is change the Main board.
      Do you know if it is normal this values in PINs 7 and 9?
      Or they change to 18V when it is necessary?
      Thank you!
        The B18VS may not be tightly regulated power supply, cannot tell until I can see the diagram.
        IT may be the same as this label: 13/18VS
        https://www.badcaps.net/forum/showpo...4&postcount=10
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
