Samsung PN50A450 - Flickering and Burn-In
  • steveh_131
    • Nov 2013
    • 33
    Hey guys, here to ask you experts for a hand on a few tv issues. I've repaired them before with your help but they just won't keep working!
    First one is this Samsung. I replaced the power board a few years back when it wouldn't power on and it's been a great tv, but now it's doing some strange things.
    Here's a video: (Pardon the dryer sounds in the background!)
    https://www.youtube.com/watch?v=BTjb7A_1GwE
    I'm noticing the following symptoms:
    • Burn-in from a round of castle-crashers a few days ago
    • Flickering, which is more pronounced when there is more WHITE on the screen, invisible when the screen is mostly black
    • Almost looks like snow on the screen, maybe a result of burn-in?
    I thought this TV had burn-in protection so I'm not sure why it's showing remnants from past activities. But would that explain the flickering? Are the issues possibly unrelated? Thanks, guys! You've helped me rescue 3 tv's right now and I've had a great time doing it!
    Steve
  • Ltank
    • Jun 2013
    • 776
    Re: Samsung PN50A450 - Flickering and Burn-In
    The video shows Mal Discharge. I highly suspect the Zsus board. It should be the right most board as viewed from the rear of the set.
    • steveh_131
      • Nov 2013
      • 33
      Ok, thank you.
      Any ideas how I should test that? Or do I just replace it?
      Also, does this explain the flickering alone or also the residual images?
      Thanks again, you rock!
      • Ltank
        • Jun 2013
        • 776
        Usually I am limited to checking high speed switching diodes, transistors, mosfets etc. Check soldering joints on heat sinked
        devices and recovery coils. I usually have not had capacitor problems on these boards. Rare but it does happen.
        • Ltank
          • Jun 2013
          • 776
          Not much you can do with burn it that I know of. Someone else might know. I rarely mess with the smd parts. Getting the oem
          parts can be a pain
            Either Z-sus or Y-sus bad, leaning more to Z-sus myself, it can cause afterimages and apparent burn in (when there actually isn't any)
            • steveh_131
              • Nov 2013
              • 33
              Ok, it sounds like the Zsus is the consensus.
              That seems to explain the snowy picture and the burn-in appearance, does it also explain the flickering on white images? The video shows it pretty well, any time the screen is mostly white there's a strong flicker.
              Steve
                It's worth checking the various voltages on the boards: Vs, Va, Vsc, etc. Flicker on white could be Z-sus, Y-sus or Vs low from power board.
                • steveh_131
                  • Nov 2013
                  • 33
                  Ok guys, I finally had a chance to pull the cover and do some investigation.
                  Here's what it looks like:
                  From what I can tell, there's a main board, logic board, x-main, y-sus, power board... no z-sus board.
                  The original symptoms persist, flickering on bright screen, remnants of past images. Now, though, I'm also noticing this pink haze on white areas of the picture.
                  I've read that this pink haze is called "banding" and that you need to adjust the Vs trimpot clockwise until it disappears.
                  Before I start tinkering, though, I'm curious if it helps point to a specific board causing the other issues (they're related, somehow) or this is just a coincidental problem.
                  I love this TV, I really hope I can fix it and I appreciate any help you guys can offer. You've all been a great help to me. Thanks!
                  Steve
                  • steveh_131
                    • Nov 2013
                    • 33
                    Ok, quick update, I now have learned that samsung's X-main is a zsus to he rest of the world. So that helps somewhat.
                    • steveh_131
                      • Nov 2013
                      • 33
                      The screenshot shows some of the haze and the artifacts.
                      • steveh_131
                        • Nov 2013
                        • 33
                        Ok, one more question for you guys.
                        My X-main (zsus) board is labeled
                        PCB NO: LJ41-05987A
                        PCA NO: LJ92-01515A/B/C/D
                        I've found a similar board here, except it's labeled A/B/C/D/E/F/G.
                        So, two questions:
                        What do the PCB and PCA models represent, exactly, and how close of a match do I need to find?
                        And is it worth spending $57 on a board that might not fix the issue, in your expert opinions?
                        Thanks, guys!
                        Steve
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
