There is no 3.2v when I turn the switch. All capacitors are good in power supply, so what's next to be check. BTW when I turn the switch manually no clicking sounds
Toshiba 42RV530 dead
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Toshiba 42RV530 dead
If I am correct, there should be a relay that bypass that inrush current limiter resistor, you should verify that the relay contact is still good otherwise that resistor will burn open circuit again.Never stop learning
