Plasma Samsung PS42C450B1W
  • catalin004
    • Jan 2015
    • 35
    Hy , I have a problem with an Samsung PS42C450B1W Plasma, when I turn it on, I don't have image on screen...it's black, I foun to X-main 2 IGBT transistors bad, and I change them....but doesn't work...I don't have a schematic diagram..
    I'm sorry for my English, but I'm from Romania....thank's you for help
  • catalin004
    • Jan 2015
    • 35
    Re: Plasma Samsung PS42C450B1W
    When I powerd on,without Y-main and X-main conected, Va and Vs start corectly, but for few seconds , then die....I have a bad power source?
      That's normal for these newer Samsung plasmas. They will turn off high voltage if X/Y fault detected.
      • catalin004
        • Jan 2015
        • 35
        So, I dissconected the cable from Y-sus and power suplly(X-main is feed from Y-main), so them are not connected...Vs and Va are presently for few seconds....If I connected Y-main (without X-main) make the same things...If the modules are not conected it means that I don't have a fault of them,no?
        • catalin004
          • Jan 2015
          • 35
          How ca I test the modules?
          • tw2005
            • Oct 2011
            • 6458
            not sure how much this will help you. when i did one of these I replaced x,y and y buffer in one go.
            • catalin004
              • Jan 2015
              • 35
              Thanks you
              • catalin004
                • Jan 2015
                • 35
                Ok, I made the verifications from upper pdf...My smps at start has Vs and Va, for few seconds....If I plugged in Y-main and X-main make same things...on X-main initially I foun 2 IGBT-s RJE30E2 in short,the smps has't Vs + Va I changed them with another, but not the same... IRG4BC40U.Now it starting, the sound of samsung it heard, but no image/light
                • tw2005
                  • Oct 2011
                  • 6458
                  I think more than just those blow, possible smd devices like the fet driver ICs and when i tried doing just those IGBTs, I then killed/shorted IGBTs on the ymain. that's when i called it quits and just did the 3 boards, but in the end just the y and x were dead, buffer was ok on mine.
                  these have an issue with xmains but being connected together y can go too
                  • catalin004
                    • Jan 2015
                    • 35
                    thank's a lot
                    • shijeesh
                      • Mar 2011
                      • 65
                      Thank you.
                      • catalin004
                        • Jan 2015
                        • 35
                        I buy another X-main, but I don't replaced yet...it's possible to be thead and I main?and kill again X-main?
                        • catalin004
                          • Jan 2015
                          • 35
                          If I remove the conection from Y-main to Control board, my tv start , and the led of control board is flashing 1sec off 1 sec on....and the X-main has a sound...a frequency sound...possible Y-main issue? I nverified the buffer's and are not in short.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            If your x main is buzzing like a frequency sound but Ymain still shuts off the tv then you have a Ymain or buffer fault.do you have VS and VA voltage with Ymain disconnected now? Disconnect y main buffer boards from Ymain and turn on tv. Does it stay on?
                            • catalin004
                              • Jan 2015
                              • 35
                              No,it doesn't stay on....Va and Vs is present only when I disconnect the Ymain logical cable,In that case Xmain is buzzing, but it warming a lot fastly....
                              • catalin004
                                • Jan 2015
                                • 35
                                Va and Vs is pressently when buffers are connected but the logical cable are not pluged into Ymain
                                • pedaltor
                                  • Feb 2021
                                  • portugal
                                  good afternoon ,, i have a samsung plasma ps42c450b1w, the main board broke down, and i bought one on ebay but i was wrong and it came ps50c450b1w which i just noticed when i set it up and turned it on, but the picture was big and deflected to the right, i ask , I can adapt this card to my 42 'TV? , is because the sign is exactly the same, can you help me please , thanks
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Can you go into the Service Menu and select your set model or screen size. Don't know if available through that menu but may be worth taking a look.
                                      09-07-2024, 05:50 AM
                                    • mi16rs
                                      Plasma Samsung PS42C450B1W no image
                                      by mi16rs
                                      Hi I have here a plasma Samsung PS42C450B1W that turn on I can ear the inicial logo sound and can ear the Chanel sound but no image and I can see that as a half horizontal black line in the bottom and the other Alf I can see some kind off color pixel . Could some one help me on this ?.
                                      Thanks...
                                      02-20-2022, 05:51 PM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
