Samsung PN60E550D1F
  • enothor
    • Jan 2015
    • 9
    • usa
    Samsung PN60E550D1F
    With this TV I'm receiving no power. The red standby light will only come on if I hold the power button in, and then it flashes very quickly until Ilet go and it's dead again. PSU to xsus readings are:
    12. Vs - Read 16 then dropped to 10.4
    11. Vs - 10.4
    10. NC
    9. Va - 0.0
    8. Gnd
    7. D15v - 15.4
    6. D5.3v - 5.4
    5. Gnd
    4. Vs-On - 0.0
    3. Vs-Con - 0.0
    2. Ps-On - 0.1
    1. Gnd
    These values don't seem to be the proper output, but I'm not positive. Any ideas or further testing you can recommend?
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Samsung PN60E550D1F
    What is the P/N of PSU? If 5.3v stby is present on PSU and there is no red standby led lit at switch module then mainboard has a problem or switch module is defective.
    The only service guide I could find is not much help. Test for 3.3v on pin 3 on switch module. If it is higher or lower then it's a mainboard problem. Service guide attached.
    • enothor
      • Jan 2015
      • 9
      • usa
      P/N of PSU is BN44-00512A. I have no 3.3v
      • enothor
        • Jan 2015
        • 9
        • usa
        On the connection from the psu to the main board, I get the following readings:
        PS-On - 0.1
        STBY - 5.3
        GND
        D15v - 15.4
        GND
        GND
        D5.3v - 5.3
        D5.3v - 5.3
        GND
        D15v - 15.4
        D15v - 15.4
        D5.3v - 5.3
        • MagicSmoke
          • Feb 2011
          • 275
          When set is plugged in but not turned on, check for 3.3v at pin 3 on switch function connector CN702. Page 5 on service manual.
          If you don't have this voltage on that pin then mainboard is faulty. PSU Voltages look OK at this point.
          • enothor
            • Jan 2015
            • 9
            • usa
            I have 3.3v on pin 3. I tried the test listed on the guide to jump the logic board and psu and got nothing. I did notice that when I was messing with the function button it would bleep and bloop but no screen activity. Once the red light went solid and then flashed slowly about five times and turned back off.
            • drussell
              • Nov 2014
              • 144
              MagicSmoke: He could be seeing the same thing with the PWM controller in the -Vscan. Once I enabled the speakers on one of the E530s here it does make the startup chime and shutdown chime noises even when the high voltages don't come up so the set is actually on with no picture.
              This explains part of the reason why people were having so much trouble getting these to come on in the morning, it actually takes 3 button presses to try to power cycle it. One for on, one brings up some kind of power off ? then one more gives you the shutdown chime and turns it off and the light goes back to solid red for standby. Tricky when you have no picture.
              enother: Does using the remote produce different results on the front panel LED than pressing the button on the set? It does here with the E530 problem... Pressing the set's controllie-button once it's in lockout just gives short blinkies. I had better results while trying to troubleshoot these using the remote power button instead, especially since to power off you're supposed to scroll the set's function doohicky to one side or something then press it again. No true dedicated "power" button.
              Just a thought....
              • enothor
                • Jan 2015
                • 9
                • usa
                Unfortunately, I don't have the remote.
                • enothor
                  • Jan 2015
                  • 9
                  • usa
                  If you know of any specific components to test on this model that often fail, just let me know. I'm pretty capable of testing most things. I'm just stuck on this set at the moment.
                  • drussell
                    • Nov 2014
                    • 144
                    I don't have the real remote here either. I'm using a UEI/URC universal remote set for Samsung. Code 1312, maybe?
                    Do you have ANY universal remote around you can try? Most of the remotes that come with cable/sat boxes have universal-for-tv features at least.
                    https://www.badcaps.net/forum/showthread.php?t=43075
                    Could try chilling your Y-Main...
                    • drussell
                      • Nov 2014
                      • 144
                      Referring to the Infineon ICE3BR0665J at U5014 right below the transformer for the -Vscan on the Y-Main board:
                      Originally posted by drussell
                      So, everyone who may have this problem, check the voltage on pin 1 (the lower right pin, indicated by the arrow on the PCB) with your meter's negative lead to ground and if you do NOT see the 0.9v when you power up the set, suspect this part. If you have freeze spray, give the chip a little squirt and you should hear it start to oscillate if the power is on (you'll have to then turn the set off and back on to get the high voltages to come up for a picture) or turn it on if it was off while you sprayed. Both of these ones here come right up and work fine until the next power cycle.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
