Bush LT26M1CA Changes Sources/Inputs
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Tv will turn on and work fine for maybe 10-20 minutes and will then change the input/source going through the list until it stops and changes to that selected option.
    Once it's done this maybe 2-3 times the TV then behaves normally and without fault.
    Not that big of a gripe but would still like to know the fault, power board looks ok, as does the main.
    Will get pictures up later
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: Bush LT26M1CA Changes Sources/Inputs
    Follow up for anyone interested, desoldered the source button off the side of the TV then resoldered it back on.
    All good now it seems, guessing moisture was the issue
      I would also clean switch with IPA and cycle a few times. Maybe consider outright replacement.
      • FlailingEngineer
        Help with Bush Tv (Vestel 17mb95m Mainboard)
        by FlailingEngineer
        Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
        Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
        05-31-2023, 06:52 AM
      • tyler123456
        Need help identifying an IC chip on a Bush DAB radio (BD-1801)
        by tyler123456
        Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
        I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
        I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
        Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
        Anyone...
        08-16-2024, 12:51 PM
      • BigOof
        Marantz SR5007 popping on volume change and mute in Direct Mode
        by BigOof
        I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
        12-12-2024, 06:15 AM
      • deeruiz
        Issue with Samsung LT23A350
        by deeruiz
        Hello!
        I have a Samsung LT23A350, model LT23A350A250NDY/ZA. The RF and HDMI inputs are functioning properly, but I'm unable to get a signal on the composite line input. I've tested it with four different working sources, including video cameras, a DVD player, and a VCR, but the TV won't display any picture from the composite input. I also tried the three component Y, PB, PR inputs, but still no picture—just a "No Signal" message.
        I checked Samsung's website for any firmware updates but didn't find anything. This TV uses a pigtail adapter with five RCA plugs, and...
        03-07-2025, 01:16 AM
      • Johnny.p
        Bush WI-1810 Internet Radio
        by Johnny.p
        I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
        U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
        11-25-2023, 04:18 AM
