Led, lg 42lx6500
  • nenea dani
    • May 2008
    • 7
    Led, lg 42lx6500
    Dear Sirs,
    I deal with LG 42LX6500-ZD, chassis LD03R that has no back light and sound after an interruption of the power grid. Now understand remote control & buttons in that enters and exits the st.by. LEDs by board operates correctly. I found absolutely nothing wrong. I changed the submicom's EEPROM unsuccessfully . There is no activity on the I2C between subMICOM and MICOM.I guess now that NAND flash is corrupt, but I have not firmware.
    Any ideas would be much appreciated.
  • Behemot
    Panasonic exits VRLA market
    by Behemot
    You guys may be interested in this - Panasonic is abandoning the lead-acid market for good. So now only Yuasa remains.
    https://www.hardwareinsights.com/pan...s-vrla-market/
    07-26-2021, 07:43 AM
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • remizbushka
    Dell inspirion 5775 bios "Unlock Setup fail"
    by remizbushka
    Hi sirs. please help
    Dell Inspiron 5775 bios locked "Unlock Setup fail"
    After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
    What I did:
    I read the bios dump.
    Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
    03-24-2025, 09:07 AM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
