IPM Question
  • mmartell
    • Oct 2013
    • 3189
    IPM Question
    Working on an LG 60PC1D atm with a shorted zsus sus ipm. Have not yet removed part. The sticker on the heatsink reads 4921QP1046B.
    Does anyone know which YPPD and STK this part crosses to ? Seems there should be an ipm matrix somewhere.
  • tw2005
    • Oct 2011
    • 6458
    Re: IPM Question
    It looks like http://www.diytrade.com/china/pd/117...21QP1046A.html
    I read somewhere the version needed to be matched(maybe Coppell TV) with the other IPM eg. B with B , C with C etc
    maybe remove it and have a look or crack it open? Or get a set and replace both. I think the other will be J016 - I'm guessing though
    Is there no white sticker on the eadge of the IPM itself?
    • mmartell
      • Oct 2013
      • 3189
      Re: IPM Question
      Don't see any sticker yet except what's on the heatsink. And the other one does have a different pin configuration so you could be right about that one.
      So I shouldn't go trying to find a J015E or other which might also be compatible then. Thanks for the input I wouldn't have known that.
      • tw2005
        • Oct 2011
        • 6458
        Re: IPM Question
        http://www.coppelltvrepair.com/p/593...lg-6871qyh057b
        suggests replacing as a pair
        • tw2005
          • Oct 2011
          • 6458
          Re: IPM Question
          Did a search and found this about mixing c with B
          Since we sell J015C and not J15B and since the mix-up of a J015C and J016B is deadly, my first guess was that they had installed J015C as a replacement of J015B and, sure enough, it would have lasted a very short time.
          I wrote back explaining that we pay premium for our J015C components (and we really do!) and that we haven't had a defective one in a very long time (and indeed we haven't!) and that perhaps they confused J015B with J015C. This is a common mistake which is the reason why in the listing for the YPPD-J015C sale we have multiple warnings about the need to use C versions for both IPM modules on the sustain board.
          • mmartell
            • Oct 2013
            • 3189
            Re: IPM Question
            That's some good info tw. I will replace with a j015b, no point in replacing both as finding new ones is next to impossible so why replace used with used.
            Also there is a scratch on the screen so I've offered to my eight year old son for gaming. He doesn't want. Can you believe that ? Admittedly he's become spoiled by gaming on a much larger front projector but it's time for me to have that back.
            • EVXIO
              Z83-V BIOS needed (Board Sticker Z85-D3X8-G-V1.2-Z8350-4G+64G)
              by EVXIO
              Beelink/AZW drop Z83 support for this device.
              I need BIOS for AZW Z83-V.
              Sticker code: Z85-D3X8-G-V1.2-Z8350-4G+64G
              Board code: Z85-D3X8-V1.2
              Known working bios version Z85_0303 X64
              filename: Z85_D303_Z83-V_AZW_window_NoPowerON0428.bin
              Thank you in advance!
              01-11-2024, 03:41 AM
            • stikerun12
              FX706IU BIOS
              by stikerun12
              Hi! I need help with this bios, have no serial number inserted and i have bsod random. I tried all option avaible from forum software, update remove, ram replace, ssd and also reballing core, change all mosfets and controler and still the same problem. The last thing is bios, i finnaly saw it have no sn inserted or i don„t know what else..
              The laptop came with this bios.
              Model: FX706IU-H7104T
              SN: LBNRCX027442469
              Mobo: DABKXBMBAD0 REV D
              ryzen 4800h
              gtx 1660TI 6GB...
              11-20-2025, 09:27 AM
            • Tom41
              USB chargers that give more than 5V?
              by Tom41
              I recently bought a portable label printer with a USB port that allows you to charge the internal battery. It comes with a USB-A to Micro-USB cable, but no charging plug. A sticker next to the charging port says "Warning! Do not use adapter with voltage over 5V!"
              Thing is, are there any USB chargers that give out more than 5V, and in what situation would that be used? Just to be on the safe side I used a multimeter to measure my chargers - one is giving out 5.11V, the other is giving out 4.9V. The warning sticker suggests the printer doesn't have any overvoltage protection...
              11-15-2025, 08:18 AM
            • blaster_
              Samsung UE49MU6105K - boot loop, horizontal lines
              by blaster_
              Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
              Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
              06-22-2022, 05:19 PM
            • kitor
              HP Pro Mini 400 G9 - Led code 3/6 Processor does not support an enabled feature / disable AMT in dump?
              by kitor
              Hey,
              I got HP Pro Mini 400 G9 waiting for a long time for a CPU. Bought I3-12100T which is on supported list just to receive code 3,6 which says "Processor does not support an enabled feature".
              After research I found this is most likely due to all the management stuff being enabled in BIOS (it has vPRO essentials I5 sticker so that is very likely) where 12100T definitely does not support it.
              Unfortunately I wasn't able to find any friend who would have and lend me their CPU to fix that... so the question is, can this be changed at bios dump level?
              I attached...
              02-03-2025, 11:09 AM
