Samsung LE32A457 bad glue? - BN44-00214A PSU
    Picked up this Samsung LE32A457 as it would intermittently fail to power on. Sometimes it would also cut out while running or the backlight would flicker but it would continue working. Or it would restart. When working, everything was OK with picture and sound. Checked PS ON/OFF signal and it was functioning as expected (on this set it's active HIGH) so it must be the power board at fault.
    I replaced the common CM808 capacitor, no dice.
    I found that by tapping around the power board it would cut out, so I reflowed a few suspect solder joints. Still no luck, still cut out when tapped.
    When it was struggling to power up, Vcc for main controller was ~9V, operational was 15V. So I focused on QB802. Input of QB802 was OK, at ~23V regardless of fault.
    Then I noticed QB802 with some glue on it, which had dried out, touching some of the pins. I cleaned this off and it's not cut out once... Anyone found this glue to be intermittent? I'm thinking that some was touching the pins partially, vibration was completing the circuit causing issues. But I've never encountered this before.
    Been working for nearly an hour with neigh but a flicker from the screen.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung LE32A457 bad glue? - BN44-00214A PSU
    Ive had that 'Orrible Yellow Construction-Adhesive cause weird Intermittent faults WAY back in 1983 on a Sony Cassette deck....
    So--Yes, It can cause intermittent faults--and they are STILL using that trash after all these years!
    TELEFIX
    • artois7
      • Mar 2011
      • 159
      Yep that yellow stuff is definitely still used! AlastairE. In a lot of units I've seen recently the yellow glue has actually turned brown through heat and goes conductive. All from a large name Soundbar company. Not sure if that's what Tom is talking about though!
        The glue on mine has turned a distinct brown-yellowish shade. I've scraped as much of it off as possible.
        I've seen it used in Yamaha equipment myself too.
        Vestel uses the white stuff which seems ok. Panasonic usually doens't bother, as they design the components to fit flush with the board where mechanical stability is important.
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
