Sony KDL-46EX1 intermittent fault ??tab bond
  • blouis79
    • Jun 2009
    • 5
    Our TV has started misbehaving. The off thing is that the TV works fine. The problems are so far limited to HDMI inputs.
    Symptoms seem like others have described with tab bond failures. Darkness in part of screen, flickering darkness across screen. Darkness looks like brightness and backlight turned down. But when HDMI inputs look like that, turn back to DTV and DTV is normal. Perfectly normal when the set is cool. Happens when warmed up. Not looking forward to getting a serviceman to bill us a large quote fee to say that it's tab bonds and we need a new set. Anticipating having to get a new one anyway. Ours reports working time 11681:36 (presume this is hours).
    Have 2 HDMI sources - PC and PS3. This TV talks wirelessly between BOX and MONITOR (screen). There are HDMI inputs that go to the BOX and one HDMI that plugs straight into the MONITOR bypassing the wireless, that's what the PC is connected to. When it misbehaves, HDMI direct and wireless via BOX both show the same problem.
    Worst behavior yesterday was when the HDMI source played very slowly with dark screen in slo-mo with ghosting of moving images.
    For some months, there has been faint scrolling horizontal bands of noise scrolling up the image only noticeable on very dark backgrounds. I presumed this was interference, but haven't been able to get rid of it. Nobody else notices.
    I've studied the available information - EG1W chassis training, service manual, Sony T-CON training manual and troubleshooting. Service mode reports no errors. Tried the power down reset procedure.
    I can't figure out how this problem could affect only HDMI sources via both wireless and direct HDMI without affecting DTV from the BOX via wireless to the MONITOR at all. On the block diagram, the only place that shows where these signals might be separate looks to be somewhere on the main board or inside the Trident WX2.
    Haven't taken to disassembly yet, since nobody will be happy with me if I kill the functioning TV by accident. Wondering if this could be a bad cap somewhere on the main board or a bad connection of an interconnect.
    Any clues would be welcome.
  • GoodCapDude
    Sony XBR-75X940E intermittent 6 blinks error code
    by GoodCapDude
    Hi everyone. First post on Badcaps!
    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
    09-20-2025, 06:07 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
  • sarry86
    sony dav-dz650 home theatre psu that has fault
    by sarry86
    Guys I am in need of your help, I forgot to discharge capacitors and went directly to check for the bad transistor, unfortunately I shorted this pwm ic, I'am not very good at troubleshooting hardware issues, can you guys help me know the similar ic to the ssc6200? It is a sony dav-dz650 home theatre psu that has fault, please help me...
    12-11-2021, 11:19 AM
