Samsung SyncMaster 710v
  • sequille
    • 33
    I know it has been discussed on this forum and around the net, but this is not the same situation. It's more like the next phase in this monitor's demise, as follows:
    It started out as "Not optimum mode" for which i applied the 50/47 ohm fix present around the web (shorting pins 5 and 6 on the Novatek chip with a resistor). It worked for around a year.
    Now I'm getting the following behavior:
    - turning it on: blank screen, green power led blinks slowly
    - removing the vga cable: i get the "check signal cable" box moving around the screen
    - plugging it back in: blank screen, green power led blinks slowly
    - pressing the Menu button: a box in the corner saying "TEST GOOD" with a 5 circles image
    If I remove the resistor i get the same behavior. The panel seems OK, i tested it with another logic board and displays correctly.
  • sequille
    • 33
    Re: Samsung SyncMaster 710v
    Oh, really sorry, I posted this in the TV forum. Could a moderator move it to the computer displays forum?
      09-07-2024, 05:50 AM
    • soopacrucial
      Samsung Syncmaster 740BF repair
      by soopacrucial
      Hi folks,
      I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
      Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
      10-29-2024, 02:40 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
