Question on a reading the surface mount Capacitor
  • jeffecor
    • Sep 2014
    • 78
    • kent
    The Capacitor say's 7N 10 10A on it. Tried googling it but can't seem to find anything on the Capacitor. Thanks
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Question on a reading the surface mount Capacitor
    Most likely a 10uf 10v 1%, why do you inquire? those type of caps are among the least likely to fail.
    Liberating magic smoke one part at a time
      Just a note probably 20% not 1%... a 1% electrolytic is extremely rare... closest is 10%.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        I thought the "A" designation was a 1% or is that only on ceramic?
        • jeffecor
          • Sep 2014
          • 78
          • kent
          Well I was trying to see that fixed the issue on the board. Because when i pushed on the board in that area the screen would work normal. But it was a try didn't work heating the board up to 385 degree helped a little. Thanks for the help!
          • Agent24
            I see dead caps
            • Oct 2007
            • 5016
            • New Zealand
            Last SMD electrolytic datasheet I saw, the letter was a voltage code IIRC.
            -David VanHorn
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              I bet flexing the board allowed the bga chip right below to connect properly, much more likely to fail
              thanks for the info Agent24
                BGA failure is a consistent Samsung problem.
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                  Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-06-2024, 08:10 PM
                  Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
