Panasonic P42c2 4 red blinks
  • powermatt
    • Oct 2014
    Guys
    SO far Ive isolated the SN (TNPA5066AB) board still 4 blinks, then isolated SS (TNPA5072) also then get 7 blinks, reconnected SN board and still get 7 blinks, reconnect both boards and get 4 blinks.
    Anyone got any ideas why it won't be the P board, or anything else I should try?
    Many Thanks
    Matt
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic P42c2 4 red blinks
    yeah, the SS TNPA5072 often fails short cct on SS11 ( vsus rail from the PSU) forces PSU to trigger SOS 4 but it's not a PSU fault
    • tw2005
      • Oct 2011
      • 6458
      Advise you also have a good poke around the Sn and see if any Transistors are short, check SN2 resistance, check the energy recovery cct short pins 1-5 , that's where the SN and SS connect(at SN3).
      Check smd diodes D451, D441 alsoo can fail short.
      it's feasible for the SS to kill the Sn especially if you're experimenting disconnecting boards. I blew up a Sn not isolating Sn3 with a shorted SS recently.
      Repair of the SS is straight forward but SMD work
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
        11-20-2024, 08:52 PM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
      • CrewmanRedShirt
        Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
        by CrewmanRedShirt
        Hello all,
        As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
        07-13-2024, 11:02 AM
      • nobbnobb1
        Panasonic TC-P50U50 Powers Off - 8 blinks
        by nobbnobb1
        I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
        2x DG302 (Q16051)
        2x RF2001 (D16041)
        2x 5.6 ohm SMD resistor
        1x BD8694 IC
        I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
        03-21-2023, 08:33 PM
