Sony XBR-65X900F black and white image on one side (fading saturation)
  • NSkyLab
    • Dec 2022
    • 19
    I though I've seen all possible kinds of failures but this one is new...
    Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
    I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
    Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4540
    • Italy - Milan
    Hi, yes it's an uncommon situation, i think the wrong side is the one at top in picture, yes? It's most possible a problem with the Vcom signal in that side, i think it's too low, check the left side distribution strip board for some testpoints named Vcom-something, it has to be around 7v (or anyway half-avdd), if it's low check the respective pin on the tcon board, if there is ok then a connection problem, or some discrete on the strip board.. bye
    • Diah
      • Feb 2013
      • 6613
      clean LVDS from both side after inspect the contact pins no one have cut at the end or not aligned, after that if every things good for you, do hard reset the TV
      • Diah
        • Feb 2013
        • 6613
        one things more need to think about it,,, you put the TV in position where the effect shown at part the TV back close to the wall, if the wall have any Magnetic caused by wiring or metal will show this on screen..
        • NSkyLab
          • Dec 2022
          • 19
          Yes, top is the issue, all pictures are supposed to be plain R, G and B. Vcom is 7.25V on both sides of the panel, AVDD is 16.8V.
          • NSkyLab
            • Dec 2022
            • 19
            Thanks, but orientation does not matter here.
            • NSkyLab
              • Dec 2022
              • 19
              Thanks. Already did all of these, no change...
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4540
                • Italy - Milan
                half avdd so vcom is supposed be 8,4v if i'm right , is there any trimmer in the panel strip board? Is vcom signal correctly reaching the panel on the last cof tab?
                • NSkyLab
                  • Dec 2022
                  • 19
                  Yes, 7.25V goes straight to the last cof tab. I compared both sides (left and right strip boards are almost identical) and voltages are equal...
                  • Diah
                    • Feb 2013
                    • 6613
                    in this case try to set the display under the 10 bits 8bits or less if available ,, and switch off HDR 10 and HLG, let see how it will act
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4540
                      • Italy - Milan
                      Sorry, yes, since vcom is the same on 2 sides it is not the wrong voltage, now i suspect another thing, i think that when it changes between full screen colors there is a lack or scarceness of the vgoff=vgl, so the pixels energized in a certain color remains charged in the next color... check vgl testpoint in both sides and especially next before the last cof tab entering..
                      • Diah
                        • Feb 2013
                        • 6613
                        OP , don't miss with Panel buffer boards by testing VDC.. who knows will great shorts. this Android SoC GPU, we do have in this forum same effect at another Android brand.
                        the one who are talking on discharge... white & Black perfect.. white R=255 G=255, B=255 black all RGB = 0 why no effect on discharge when value at cells go high and down !!! funny
                        • NSkyLab
                          • Dec 2022
                          • 19
                          Main board is disconnected. This lower level issue.
                          • NSkyLab
                            • Dec 2022
                            • 19
                            Android has nothing to do with that since the issue is on the physical level, not software level. The panel physical interface is not plain RGB, it does have a signal to explicitly switch pixels off. Davi.p may be on the right track...
                            • NSkyLab
                              • Dec 2022
                              • 19
                              I can't find the vgoff testpoint, but I measured every testpoint I could find and they are identical on both sides... Pretty sure it's in the COF. So it's going to the dumpster today.
                              Thanks for help.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4540
                                • Italy - Milan
                                oh, so a sin, i have tried a better explanation because i was indeed not convincted, but i needed a repassing of study of panels basis, unfortunately i am at work now.. the thing is surely something of this: there's a leakage from one of the source data bits to the other data bits, this in the area from output of tcon towards the faulty side, until the rest of the faulty side panel, source data bits are mixed and almost serial in that area, when them arrives to source COFS them are disassembled in the DAC+shift registers inside COFS, somehow there is a parasite capacitance that mixes up RGB data thogether, when RGB columns have to be displayed all 3 at 0 level (=vcom) then the mixing has no effect (black displayed well).. in the ending i could suspect maybe some dirt in strip board, or some bad /missing EOL resistor near the source COFS, them has to be all 100ohm.. bye..
                                • NSkyLab
                                  • Dec 2022
                                  • 19
                                  If I properly got what you've described then I'd expect to see some artifacts or crooked colors... I didn't post those photos, but the picture looked fine, there were proper colors, except the saturation on the left side. According to the owner it was gradually getting worse over the last few months...
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4540
                                    • Italy - Milan
                                    Excuse me, what i see is not full saturation, is something like solarization, at this purpose the there can also be an issue at gamma correction, if there are gamma test points on the strip board can be useful to check them, do you know how? about the data bits problem that i said, suppose the screen is 10 bits, every sub pixel is defined by them, suppose full red screen is displayed, and most significant byte of red shorts to most sig. byte of green & blue, the result is white or washed white, what i do not know is where the short could be, if i'm right, mini lvds data bus has one line that holds data for all 3 RGB, for example it could hold bit7+8 of each byte of RGB, so the most significant byte of all 3 components RGB, each line is made of 2 conductors for differential signal, if one of the couple is opened could determine a bad digital signal...
                                    PS: sorry, very hard to type with cellular and my big inches..
                                    • Diah
                                      • Feb 2013
                                      • 6613
                                      as you like and think... but you are wrong read about GPU , GOOD LUCK WITH YOURS TRACK
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4540
                                        • Italy - Milan
                                        Ok forget about the last posts, the problem is not source data, i forgot the fading issue, the problem is surely in gate drivers or gate signals.. let me think on..
                                        well, the fault must be about the usual copying of the signal through the scan of lines, the common trail/ghosting of the various lines, so this can lend to bad gate signal, lack of vgl as i said before, the lines are not turned off, so when cpu displays red, and after green, the red dots remains red fading gradually due to pixel capacitance, vgl could be ok on the strip board but could be weak after the cof tab passage, due to maybe silver tracks oxydation, a possible test of it could be providing hot air to the back of the last cof tab, the hot air deoxydizes a bit.. this does not explain fully the good checkered screen test displayed well, this is not important as this remembers me the old days with the Samsung LExxA756 series tv where the tcon self test with checkered graphics was displayed ok but normal video was full of ghosting/ vertical smears
                                        pursuing the reasoning and remembering, i have still an old Led tv from Samsung, the common UexxB6000 series with the same common fault of the A756, i verified on its tcon an error on one of the clocks signals, i never had a scope but with my 10 euro super multimeter i tested the frequency of it that was not 15khz like others but a much wrong value, also its voltage was no good, this can be due to bad level shifting job or bad buffer ic job.. check if there is a buffer chip on the bad strip board.. the A756 had a buffer chip on it..
                                        PS: high saturation is when colors are too charged, but actually low saturation is when colors are washed out, but this image tends to strong white like bad gamma correction
                                        • Watson306
                                          6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                          by Watson306
                                          I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                          I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                          I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                          Many Thanks in advance.
                                          11-01-2022, 05:33 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • Piotr4509
                                          Fading picture on Sony 48-WD 655 TV
                                          by Piotr4509
                                          Hello everyone on the forum. Electronics is my hobby, so please be understanding. I got a Sony KDL-48WD655 TV for free, which did not turn on at all from the remote control or the "on" button, after a long search for the diagram, I reached this forum where I found a diagram and a similar case with a person from the forum. Using the hints from one thread, I started the TV by bridging the TPC 8129 source with a 10k ohm resistor. The tv turns on and off, the "+" and "-" buttons aloud also function, which is broken in this section I would like to address later because...
                                          05-02-2023, 09:48 AM
