Samsung PN51D550C1F died, won't turn on, clicking
  • ehboy
    • Sep 2014
    • 66
    Hi. My TV died right before my eyes. Just went black, flashing power light at front twice in a row constantly. Won't turn on at all.
    When tries to power up, it clicks five times, then stops trying.
    I am new to this, so please bear with me
    The vs-tp with y main unhooked is about 115 when multimeter is set to 500 DCV
    The va-tp with y main unhooked is about 35. Both of these decrease after initial plug in.
    Values are the same when x main is unplugged.
    Thanks for any assistance that you can render. Build was apparently Nov 2011. It has been ok till now, had to do some adjustment back in winter to get rid of purple banding that was occuring.
    Thanks.
    Re: Samsung PN51D550C1F died, won't turn on, clicking
    Can you confirm if the screen flashes briefly when it tries to turn on?
    • ehboy
      • Sep 2014
      • 66
      No sir, I haven't seen that behavior. It simply seems to just click and then the front power light constantly does a double pulse. Thanks.
        OK, can you provide some pictures of the power supply board, the Y-main board, and the X-main board?
        Power supply board - AC power connects to this
        Y-main board - On the left hand side of the TV looking from the rear
        X-main board - On the right hand side of the TV looking from the rear
        • ehboy
          • Sep 2014
          • 66
          ok will do when i get the chance. i cannot see any bulged caps or anything...
            I'm looking for test points, mostly.
            • ehboy
              • Sep 2014
              • 66
              Here are the 3 boards, tom66. Thanks.
                OK there is a test point on the Y-main marked VSCAN... can you measure the voltage on this point (highest DC range or auto-ranging DC volts) using a digital multimeter. Place red probe on the point and black on the chassis. Note if it changes while powering up/clicking.
                • ehboy
                  • Sep 2014
                  • 66
                  I have no movement whatsoever. The needle is still at 500DCV.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    Fellow albertain !! What city are you in?
                    Also,I might have boards for this TV,got a couple of this model sitting here...
                    Proud owner of dozens of broken TV's and many,many,many boards.
                    Our website and passion:http://hollenhundshepherds.com/
                    • ehboy
                      • Sep 2014
                      • 66
                      tom66 would you happen to have any further ideas for this problem? Greatly appreciated.
                        Can you remove the Y-buffer board (connected to the Y-main) and see if the voltage on VSCAN rises
                        • ehboy
                          • Sep 2014
                          • 66
                          ok
                          • ehboy
                            • Sep 2014
                            • 66
                            I get no movement on vscan at 500 dcv. There MIGHT be a slight movement, but it might be from vibration...
                              I'm guessing you are using an analog meter, is it possible you could borrow a digital one to confirm?
                              • ehboy
                                • Sep 2014
                                • 66
                                I don't know of anyone...I am certain now that I have redone it that there is no movement on the 500 dcv. I think it was me moving.
                                • wtdenk
                                  • Sep 2014
                                  • usa
                                  I just joined here hoping to get some advice on this exact same situation. Wishing you luck
                                    It would seem like your Y-main board is bad, then.
                                    • ehboy
                                      • Sep 2014
                                      • 66
                                      ok. so then i should order one seems like shopjimmy is out of stock...can you recommend another source at all? I really appreciate all of your help.
                                      • ehboy
                                        • Sep 2014
                                        • 66
                                        My part says revision number 1.5 Would the exact part with a 1.4 revision work?
                                        As well, on the UPC bar code, it says 764D. Does it have to have this exact same number, or would a 764A or 764B work?
                                        Anyone's advice is much appreciated. Thanks.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
