Samsung PN51D550C1F died, won't turn on, clicking
  • ehboy
    • Sep 2014
    • 66
    Re: Samsung PN51D550C1F died, won't turn on, clicking
    Seems to be working well. I had to adjust the VS from 107 up to 113 to deal with the dreaded pink banding issue. I checked for this to make sure before I closed it up, luckily. I had this problem before the boards went kablooey, so I am not surprised I had to up the VS again.
    Thinking about it, I am wondering if 6 plus months of higher voltage caused the x main to blow in the first place....may be a connection?
    • Hobb3s
      • Nov 2014
      • 9
      I'm in the same boat for the same tv, anyone have a source for the x-main for this one?
      • Hobb3s
        • Nov 2014
        • 9
        I was wondering if I got a different revision of the same board, would that work or would I end up frying something else. It seems there are lots of Rev.1.2 around, but mine is 1.3
        • vinniebonez
          • Nov 2014
          • 5
          Hey Hobbs, I have the exact same problem! exactly the same tv!
          Should we do the same thing that ehboy did ?
          I ordered a new x-main - the PBA number is the same but the actual board looks a bit different. i will upload those pics.
          here is the video.... i have a digital multimeter but i have no real experience.
          http://youtu.be/d7Z2c7u_nj8
          • vinniebonez
            • Nov 2014
            • 5
            this is the original x-main
            this is the new x-main i ordered off of ebay
            the new one looks like there are 2 transistors missing ??
            you can zoom in and see the PBA number match.. are there other part numbers that i missed before ordering? am i even replacing the right part?
            how can i use the multimeter to check if these or ok? OR ANY ADVICE? thank you
              You have the 720p X-main. You cannot use it in your 1080p set unfortunately.
              It might be possible to upgrade the 720p X-main to behave like a 1080p one, this would involve swapping quite a few parts across and buying additional ones.
              It's weird, in the UK the 720p one seems to be in good supply, about £30 ($50USD), and the 1080p one is near unobtainable. Wonder if the 1080p one fails more often?
              • vinniebonez
                • Nov 2014
                • 5
                ahhhh - so Tom, i should look into ordering a 1080p x-main, you think that's what the problem is ?
                • vinniebonez
                  • Nov 2014
                  • 5
                  i have those 2 boards for 720p i guess if anyone needs them
                  • vinniebonez
                    • Nov 2014
                    • 5
                    Thanks for your help TOM66
                    How did you identify i ordered a 720p board?
                    where can i find the 1080p board that i need? I really don't want to order the wrong part again
                    • ShadyAtBest
                      • Apr 2015
                      • usa
                      #90
                      So. I just read through this whole thing and it seems that the problem was never discovered.
                      My tv just stopped working the other day. The red led in the front double blinks, I can hear clicking like maybe a relay or something. Picture does not appear or flash. I guess I have to find one with a broken screen and part it out
                      • paknoy
                        • May 2014
                        • 6
                        • usa
                        #91
                        HI, Vinnie,
                        I was just wondering what happen to your TV after plugging the new Y board LABEL DH-G
                        we had pretty much the same issue here my TV wouldn't turned on at all only blinking Red light and clicking noise, I manage to find a Y board label DH-G but my original Board Label DF-G I had noticed slight difference missing one green capacitor.. but anyway I di plugged in a replacement YBoard and got excited because the TV turns on without pressing the power button on remote but after few minutes it starting to smokes not from the board id just replaced it was coming from the other y board immediately unplugged the power supply but before I did that the screen started to fades out (blurry,distorted ) but anyway I was just curious to know whether this happen to you as well... SJimmy does not have anything available at this moment neither Ebay.
                        • nhoj612
                          • Jun 2016
                          • usa
                          #92
                          Hot the same problem on same model tv. As of niw no Va ir VS voltage, Y and X biards are disconnected only logic and main board. I have a slow steady pulse on the logic. Is it a bad power supply board? All caps looks fine Im thinking starting to remove the mosfets and test them. Any advice which component to look on the possible bad power supply?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #93
                            Have you measured the voltages on the power supply to see if they are all up at their correct voltages before removing components.
                            https://www.youtube.com/watch?v=-7zWKY2Hwnc
                            • nhoj612
                              • Jun 2016
                              • usa
                              #94
                              Found the problem, one if the driver chip on the y buffer blown causing the VA VS to 0 in the power supply. I isolate the ribbon cable from the logic board. Now with just the PS, Logic and Main board connected got the Voltage right and normal pulse on the Logic board. My question now is since one if the driver chip is fried on the Y buffer, should the Y sus board fried too? And change also the X sus? The X sus are connected to the Y sus. Thanks
                              • General-lee1969
                                • Jan 2016
                                • 6
                                • canada
                                #95
                                Just wondering if you ended up fixing the tv with just a y-buffer and y-sus or did you have to get the x- main as well.?
                                • markpelly
                                  Does anyone have a 1080p Xmain and Xbuffer I could buy? I am not finding any available online, only 720p versions.
                                  When I plug in my TV the Xmain and Buffer both make a soft humming noise, but no picture. When I turn the TV off after that it wont turn on again. The light blinking changes on the controller.
                                  • JDMRpr78
                                    • Feb 2018
                                    • 31
                                    Old thread I know but same issues.
                                    Took a video if anyone could provide some assistance
                                    https://youtu.be/Gn4SmvjsdpE
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
