Samsung Plasma Display (50 inch) HP-S5033X/XAA |Video comes on/off (back on with hit)
  • ritch
    • Aug 2014
    Hi guys, I'm hoping someone can give me an idea on how to repair my 50" Samsung Plasma Model HP-S5033X/XAA.
    It works most of the time but a several times a day the video will go black but the audio still works. It will then sometimes flicker back on/off. If I hit the back of the TV the video will pop back on. Usually it will stay on for hours after this, for example it happened 6 hours ago and it's still working.
    I'm hoping it's a loose wire/connection I could fix. Any ideas?
    Thanks in advance,
    Ritch
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung Plasma Display (50 inch) HP-S5033X/XAA |Video comes on/off (back on with
    Hey, Fonzie, the easiest thing to do is to remove and reseat all cables and ribbons and see if that fixes the problem. If not you may have a bad solder joint but I have my doubt you can fix that with a good whack.
    Also, take a screwdriver and make sure all screws that are holding on the various boards are tight as they are used as ground.
      A common issue with this model is cold solder joints on some transistors.
      You must repair the issue soon. If you do not, eventually some components on the power supply will be damaged, making the repair much more extensive, so for now, discontinue use of the TV.
        09-07-2024, 05:50 AM
      • littlejohn
        samsung PN50A550S1FXZC plasma no video
        by littlejohn
        Hello, I have a Samsung 50" plasma PN50A550S1FXZC ,The tv comes on and chimes and got audio of some shopping channel , but I have no video .All the voltages are OK on the power supply board Vs 204 Va 57 also have 18v, 5.3v , 12v and 3.3v. I put it in test mode and get different colored screens and test patterns. the logic board has 2 upper LED's that flash at 1 second intervals , there is a lower LED that comes on when the power button is pushed for about 3 seconds and goes out before the tv does it's welcome chime. there is no faint image on the screen in a dark room with a flashlight shining...
        03-29-2022, 05:35 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
