Samsung ue46d6200 fails to start
  • Mr_K
    • 111
    here i have a faulty Samsung ue46d6200. The problem is, that the TV won´t boot/or stay on. After switching the TV on I can see the picture for about half a second. After that the TV "reboots" itself. The standby LED flashes 4 times. Than the Backlight comes on for maybe half a second and the tv restarts again. This is an endless loop.
    I have narrowed down the problem to the Main PCB. Its an BN41-01606C.
    Does anyone know if the is a fixable problem? Maybe someone has had a similar problem? A replacement PCB is quite expensive at the moment so i´d like to fix this by myself.
    So any help appriciated
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung ue46d6200 fails to start
    Since it is a D series, I would suspect the panel.
    Remove the ribbons, between the T-con and panel PCB, one at a time.
    If you will have good image on half of the screen only, then it's a bad panel.
    • Mr_K
      • 111
      Thx tibimakai. I´ve already tried that. For testing, i used the mainboard of an UE40D..... tv. With this board, the tv is working fine. I think it is def. a problem with the main PCB.
      • Mr_K
        • 111
        I do not know anything about the history of the TV.
        Do you think this might be software or hardware related? Im wondering if an eeprom reset might help here? On the other hand, the tv boots up fine and reboots itself after that.
        • PDMAN
          • Aug 2014
          • 37
          You may have answered your own question. If it's working fine with that replacement PCB why not get the proper Mainboard. It should work.
          • Mr_K
            • 111
            I know. But this will cost >200€ Quite a lot for a D-series repair....
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
              09-06-2024, 11:40 PM
