SAMSUNG MAINBOARD COMPATIBILITY BN41-02751B
  • bohaboha
    • Nov 2012
    • 1035
    • sweden
    Hello everyone, hope you have had a lot of sun and a nice summer.
    I wonder and hope that these two Mainboards are compatible because they look like twins. one Native is BN41-02751B.000 and the same thing on the other printed on the circuit but they differ what is on the stick Native BN94-16627N the other BN94-16103q. don't know if the region issue can cause problems
    or maybe it's a dump question or even a settings question for them to fit
    is there anyone here who can help me sort out this question very thanksm
  • bohaboha
    • Nov 2012
    • 1035
    • sweden
    Hello no one who can give any clue how to solve this situation
    • bohaboha
      • Nov 2012
      • 1035
      • sweden
      This Thread seems to be ignored
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Did you put it in the TV and try it,what happens
        • bohaboha
          • Nov 2012
          • 1035
          • sweden
          Hi EazyBone yes i did but the set starts but no pictures the screen remain black i was thinking like plug and play but no
          the boards are almost identical it have to do with programming or maybe a dump but i do not know which chip to programme please if you have any idea just point it to me thank you
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Try this
            with set on, press info, setting[menu] 314 exit, then unplug the ac cord
            • bohaboha
              • Nov 2012
              • 1035
              • sweden
              thank you i will try it in the morning but please any idea about the IC to get a Dump if you can point it thank you again
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                When Samsung boards are compatible this key press will make it work.
                No data on changing any of that stuff you intend
                • bohaboha
                  • Nov 2012
                  • 1035
                  • sweden
                  Originally posted by EazyBonhee
                  Try this
                  Hi again and very sorry for the late answer because i got that Philps 75 beast . i did that test and i get some response not really good but a big step in the front take a look a those pictures first it start very clear and nice with small defect at the upper edje and then as you se
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    Did it have any pictures before you did this?
                    All I know is the code, I was given it and relaying the data unsure what this means for your tv
                    • bohaboha
                      • Nov 2012
                      • 1035
                      • sweden
                      before i use the code it was nothing on screen so it is a good progress and everytime i repeat it the pictures get better
                      just when it s starts but after 10mn or so the screen get creasy
                      • bohaboha
                        • Nov 2012
                        • 1035
                        • sweden
                        Hello, now the TV is on a better way the picture and the sound is present, but the picture is very fad, the code you give me did a lot, but it seems that the set needs a little more nice tuning maybe in the TV setting or in the service side don't know I'll take some pictures when I get home
                          09-07-2024, 05:50 AM
                        • Nairolf
                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                          by Nairolf
                          I have a Samsung DM32D display.
                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                          Here’s what I have tried so far:
                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                          08-24-2025, 03:47 AM
                        • bohaboha
                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                          by bohaboha
                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                          04-19-2025, 01:47 PM
                          09-06-2024, 11:40 PM
