LG OLED65C7V-Z power issue
This topic has been answered.
  • Kievan
    • Aug 2025
    • 14
    • Belgium
    Hello, I'm trying to repair an LG OLED65C7V-Z that has no picture and no sound. When I plug the TV, I hear the relay click. When I push the power button, i hear a second click and there are 3 red blinks but no sound and no picture.
    I checked the voltage at the power board and I have the 20V and 12V at the mainboard connector, I have the 12V at the T-CON connector but not the 24V.
    I tested the power supply without the T-CON and the main board by injecting 3.3V into the PWR_ON pin, the DPC pin and the 12VT_ON pin but still no 24V.
    I checked the fuses, the diodes, the capacitors and I checked for shorts circuit on the power board and T-CON but nothing strange. The big transformer (in red) has 53V at his inputs but nothing at his outputs. The transistor (in blue) has 10 V between the middle pin and the others while the transistor right next to him has 110V, I checked the transistor in blue out of the circuit and he is fine. I checked the temperature with IR cam and nothing above 50°C.
    I don't know if it is the T-CON board or the power board that has failed and if it is the big transformer (in red) that has failed.
    Already thank you for your help and sorry for my English, I'm not speaking english regularly.
  • Answer selected by Kievan at 08-20-2025, 05:10 AM.
    Kievan
    • Aug 2025
    • 14
    • Belgium
    I bought a new mainboard and now the TV functions properly. This is a mainboard for the 55 inch model but, for now, I have no problem. I'll maybe install a new firmware if a problem occurs.
    Thanks for your help.
    • MiltonSchuster
      • Aug 2025
      • america
      Is your problem now fixed?
      • Kievan
        • Aug 2025
        • 14
        • Belgium
        Unfortunately not.
        • lotas
          • Jan 2016
          • 4661
          • Russia
          In order for the desired 24V to appear, on pin 23 (DRV_ON) of the power supply, a command to turn on must appear from the motherboard...
          • Kievan
            • Aug 2025
            • 14
            • Belgium
            Thank you, I applied 3.3V into pin 13; 23; 10; 24 and I got 22V and all the voltage were correct. So I guess it is not the power board, I'm going to investigate further on the main board tomorrow.
            • Kievan
              • Aug 2025
              • 14
              • Belgium
              I checked the main board and I found a resistance of 20 OHMs in the red area, it is not a short circuit but it is low so I checked the temperature and nothing overheat, the voltage at the capacitors are less than 1V. I tried powering the TV without some connections but that didn't change anything.
              When I plug the TV in, there is one click and one second after (without pushing the power button), a second click and the voltages appear (except the 24V) and stay on until I push the power button or disconnect the tv.
              • lotas
                • Jan 2016
                • 4661
                • Russia
                Low resistance and low voltage (0.9 -1.0v) on the CPU core power rail is normal.
                • Kievan
                  • Aug 2025
                  • 14
                  • Belgium
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
                  • claws77
                    lenovo flex 5 14itl05 power sequence issue
                    by claws77
                    hi guys, my motherboard will not start no matter what
                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                    but rest nothing happens no sign of life.
                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                    i have no knowledge of motherboards ....
                    10-20-2024, 02:48 PM
                  • yaya3gmax
                    Laptop Power Issue – Works on Battery, Fails on Adapter Load
                    by yaya3gmax
                    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                    Symptoms:
                    • Laptop works normally on a pre-charged battery.
                    • Battery does not charge when adapter is connected.
                    • Without battery:
                      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                      • Speakers “pop” when power cut occurs indicating harsh sutdown.
                      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                    08-21-2025, 07:16 AM
                  • SuperJames
                    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                    by SuperJames
                    This one's a weird one, and still unsolved despite it having gone back to Dell once.
                    Specs
                    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                    Backstory
                    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                    10-23-2023, 04:09 PM
