17pw26-5 i have this power supply which has 3 missing voltages which i have shown in the picture,,the 33v,the 24v and the 30v.my question is do these voltages come from the psu or do they come from the mainboard once the tv is on.
vestel 17pw26-5 voltages question
Tags: None
Re: vestel 17pw26-5 voltages question
PSU; only available when the ST_BY line is asserted. (High or low, Vestel is inconsistent.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by CapacitorialHello guys,
I have a Philips 240B7QPJEB. The monitor seems completely dead.
I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
The weird thing is, that the Power LED is powered over the TCON board.
On The TCON...-
12-28-2024, 02:12 PM -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by France_53Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu... -
by lberkaniHi everyone,
I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
- Toshiba 65UL2163DG
- Vestel 17MB180E mainboard
- Panel VES650QNTX-N2-N42
- Version V1.28.100.0 if available
If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt... - Loading...
