I have a new project. A samsung plasma PN50A650TIF. I set everything up to see what was going on with this tv. Tv works great for about 10 - 15min. then all hell breaks lose with the picture. sparklies , light and dark shadows, so much going on don't know how to describe, great sound. Set works perfectly for about 10-15 min. then it goes crazy. Samsung tech told me it was either x,y main board fault, but I heard these tv were famous for logic board fault, with A series tv's. Any suggestions on where to begin would be greatful. Voltages all seem to check out, however I did them in the begining while set was working fine. did not check while set was going crazy.
Samsung Plasma PN50A650TIFXZA
Tags: None
Re: Samsung Plasma PN50A650TIFXZA
A picture of the fault could help...Also pics from the boards...
10-15minutes fine then crazy sounds heat related(cracked solder joint/temp sensitive component)
What you could try is take a hair dryer,and blow hot air on the boards,one by one,and see if you can get it to act up..That can tell you what board is doing it...
Also,if you have a can of air(pc cleaning etc) you can freeze the suspect area after heating it,by holding the can up side down and spray a bit...
Great way to zoom in on the bad spot..
Did you check if all the connectors are seated correctly? Especially around logic and main board?Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/ -
There is a common issue with these and a particular tantalum capacitor on the underside of the main board can fail causing this.Last edited by tom66; 07-27-2014, 03:11 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Martino, and Tom. thank you for the info. I'll start with pics and new voltage readings on all the boards. Again thanks for all your help, I just was anxious to get started. GeorgeComment
Gentlemen, trying to figure out how to upload these pics, this may take awhile. I will try to get new voltages when picture starts to go bad. Will also try to get set to go bad by using hair dryer on boards one at a time.Comment
Gentlemen, i can not get my pics to upload, using Manage Attachments, every time I go to upload my chosen file, after 3/4 of the download process, I get an error message saying web can not be found. can anyone help? I don't want my thread to stall, with no new info avaliable. I'll try later.Comment
You can for now upload them to a website such as http://www.imgur.com/ and supply us the links. Imgur tend to be reliable and keep the files for a long time.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Martino, I did try the dryer with no effect. All voltages coming from power supply are correct per label.Comment
Thanks Tom, any suggestions on where to go from here. Picture starts to have color bleed as well. red mostly, but hard to describe without pics.Comment
Gentlemen, Going to try to upload these pictures today, again for the third time.Can't understand why this is not working for me. I was looking at these pictures, and they resemble Gamma IC problem. I have 9 photo's in my Album here, not all of them yet. Trying to get fault pics on now. thanks I'll get them here sooner than later.Comment
Since your TV is a plasma, it would not be affected by a gamma IC problem.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Tom, thanks. I got the pics on Imgur.com finally. If you want to view just go to http://rccrasher65.imgur.com Thanks again for all your help. GeorgeComment
I cannot see any photos, did you set the photos to be publicly viewable?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
edit!! me and tom posted the same timeLast edited by vinceroger69; 07-29-2014, 12:18 PM.Comment
To view images, have to go to rccrasher65 and click on images. Album can be viewed then Thanks.Comment
yes,sorry guys, i can view but I guess it shows empty. I will get my daughter to do these pics, I have no clue what i'm doing here. I appologise for waisting your valuable timeLast edited by rccrasher65; 07-29-2014, 12:43 PM.Comment
I can now see the pictures.
To me, the fault looks like Y-main.
The Y-main is this board:
http://i.imgur.com/OfyR7wC.jpg
On it there will be a point marked VSCAN. Can you test this point on volts DC? Red probe on point, black on chassis as ground. It should measure similar to the panel rating, about negative 200V DC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Tom, Thank you for taking the time to look at these pics. Hope they are showing for everyone now, as I don't have a clue what I'm doing. I left tv on for about an Hour today and another symptom appears, picture seems to get a little better with time, but starts to flash on and off steady. I will check that voltage and get back to you. Thanks again for all the help.Comment
Tom, I checked VSC. voltage My panel shows this to be -195v. My reading was -195.6 to.7 on startup. I waited about 10min when fault starts, and did it again, reading dropped to -130v's, and pulses between -130v to -110v. Picture flashes on and off, on and off, readings match this on and off pulse.Comment
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
