How to fix Hisense 43A6H 4k Google TV - 10 Blinks?
  • chris89
    • Jan 2015
    • 69
    • United states
    Hi I replaced the mainboard, the t-con, and wifi, still no dice.
    Any idea on what it could be, causing the tv to not turn on? Just blinking LED light.
    Processor gets hot so I know the Mediatek MT9612 is functional.
ID:	3594026 Click image for larger version
    Last edited by chris89; 03-15-2025, 06:54 PM. Reason: Adding pictures if it helps?
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Does backlights come on when you hit power?
    If not take a flashlight to the screen after hitting power and look for image.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Sounds like the TV version of an RROD. Unfortunately, you will have a replace one or more components, most likely.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Non stop blinking led on Hisense usually means no Internet connection. So probably not rrod. Still should check if backlights are working
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Test the Backlights with a Backlight Tester. Most likely the Backlights are defective.
