Help required samsung plasma ps50-c7hdx
  • Andyegerton
    locksmith
    • Jan 2014
    • 17
    • Uk
    Hi guys new here but taking this hobby serious. A couple of questions first.
    What is the best way to clear out loads of dust from a tv?
    And I am after a isolation transformer to make testing safer and to be able to use my scope safely, can anyone point me in the right direction with a link? I have seen one at rs components but not sure if I need to disconnect the earth from the secondary side?
    Right then. The tv
    Samsung ps-50c7hdx/xeu was given to me, it had a blown chip on the upper y buffer board, I have replaced the board and found shorted ziner diodes on the y main board which have now been replaced ( was given the tv in disassembled state so did these repairs before I could power up) when powering up I get very red screen sometimes goes black can't see any menus, not had source connected so can't confirm sound at this stage. Va is fine at 65v but vs states on sticker 202v, I get 201v for a few seconds then when the panel lights up it drops to 188v any ideas are most welcome
  • Andyegerton
    locksmith
    • Jan 2014
    • 17
    • Uk
    Re: Help required samsung plasma ps50-c7hdx
    Model sticker if you guys need other numbers
      Which chip on the buffer did you replace. Tried it with just one buffer?
      • Andyegerton
        locksmith
        • Jan 2014
        • 17
        • Uk
        It was one of the big square chips but I just replaced the whole upper board
          It looks like your lower buffer may be bad. Can you supply a picture of the Y-buffer and Y-main boards.
          • Andyegerton
            locksmith
            • Jan 2014
            • 17
            • Uk
            Here is a picture of the back can get closer later if you need it
            • Andyegerton
              locksmith
              • Jan 2014
              • 17
              • Uk
              Replaced the upper board, both boards were connected in the picture
                What do you get on the screen with the LOWER board unplugged from the Y-main, but the upper still in.
                • Andyegerton
                  locksmith
                  • Jan 2014
                  • 17
                  • Uk
                  Here is a picture of what I get seems to be blank unless I press menu or source. Checked voltages and vs is now 201.9. Close enough to 202
                    Can you attempt to locate the Vsch and Vscan voltages (Vscan may also be called Vsc or -Vsc.) Vsch is tested across the buffer board's negative and positive, as if you were testing it for a short circuit. If unsure post a close picture of the connectors going to each board.
                    • Andyegerton
                      locksmith
                      • Jan 2014
                      • 17
                      • Uk
                      Bit more info, I tried just the bottom board and got similar results and when both boards are connected vs is 201.6. I have also noticed buzzing noise from y main board
                      • Andyegerton
                        locksmith
                        • Jan 2014
                        • 17
                        • Uk
                        Bottom buffer connection
                        • Andyegerton
                          locksmith
                          • Jan 2014
                          • 17
                          • Uk
                          Top buffer connection, also shows Zener diodes I replaced
                          • Andyegerton
                            locksmith
                            • Jan 2014
                            • 17
                            • Uk
                            Connection to board
                            • Andyegerton
                              locksmith
                              • Jan 2014
                              • 17
                              • Uk
                              Not sure of the test points
                                OK on this connector
                                https://www.badcaps.net/forum/attach...1&d=1404677915
                                Check voltage from top most pin to bottom most pin.
                                • Andyegerton
                                  locksmith
                                  • Jan 2014
                                  • 17
                                  • Uk
                                  Right the voltage was 135.4 on the upper and lower buffers. Then one of the lower buffer chips blew. Bugger
                                  • Andyegerton
                                    locksmith
                                    • Jan 2014
                                    • 17
                                    • Uk
                                    Pop
                                    • Andyegerton
                                      locksmith
                                      • Jan 2014
                                      • 17
                                      • Uk
                                      Will swap out the blown chip this weekend, can the y main board be tested without the buffer boards connected?
                                      • Andyegerton
                                        locksmith
                                        • Jan 2014
                                        • 17
                                        • Uk
                                        Anyone know how to get the glue from round the chips on a samsung
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
