LG 50PG20 720p Plasma TV
  • bullwinkle
    • May 2009
    • 107
    Need help again. My friend gave me this LG 50PG20 720p Plasma TV.
    But here is the problem and what is the cause for this particular problem?
    Note: Screen has no cracks.
  • bullwinkle
    • May 2009
    • 107
    Re: LG 50PG20 720p Plasma TV
    Is this repairable?
    • bullwinkle
      • May 2009
      • 107
      any suggestions?
      • bullwinkle
        • May 2009
        • 107
        More info:
        Once I press the power button, the display will be shown like the attached pics. But after 5 seconds, it shuts off and the LED indicator turns red from blue. No cables connected. Only AC power cord.
        • bullwinkle
          • May 2009
          • 107
          Powering up I see: Vs = 193.4V (194V printed on sticker) and Va = 60.1V (60V printed on sticker).
          • bullwinkle
            • May 2009
            • 107
            Additional info:
            -Vy = -195V
            Vscan = 135V
            Z-Bias = 98V
              All voltages are OK. Can be panel gas leakage. It doesn't need to be a large crack to cause this. Just a tiny chip can do it. Also check the gas filling pip above the Y-buffer or Z-sustain board. If you have a scope check the Y-sustain & Z-sustain waveform.
              • bullwinkle
                • May 2009
                • 107
                Many thanks tom66. But unfortunately I dont have a scope to check.
                • bullwinkle
                  • May 2009
                  • 107
                  can i post a short video clip here? just asking
                    You can use YouTube and give us the link.
                    • bullwinkle
                      • May 2009
                      • 107
                      https://www.youtube.com/watch?v=PogrAJbCaTE
                      • bullwinkle
                        • May 2009
                        • 107
                        Any other inputs that we can look into?
                        • bullwinkle
                          • May 2009
                          • 107
                          Shorted 12V rail? Since it will just turn off less than 5 seconds after power up. My guess
                            Is that a relay clicking off at the end? High white fault image like that could cause the PSU to shut down.
                            • bullwinkle
                              • May 2009
                              • 107
                              yes theres a faint relay clicking at startup but the shutdown relay clicking is more audible during recording
                              • bullwinkle
                                • May 2009
                                • 107
                                @ tom66: any suggestion?
                                  I think the panel is bad myself, but I could be wrong.
                                  Try tweaking Vsc and -Vy on the Y-sustain board.
                                  Try tweaking Yrr/Yfr too.
                                  Your panel is in here, PDP50G1, page 79:
                                  Of note, "If V-Set-Dn exceeds 120us the unit will shut down".
                                  • bullwinkle
                                    • May 2009
                                    • 107
                                    Got rid of the unit. Its the panel.
                                    Thank you tom66. You are correct.
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      hey,your from Edmonton ! I'm by Ponoka.
                                      Could be handy for swapping boards etc....
                                      Proud owner of dozens of broken TV's and many,many,many boards.
                                      Our website and passion:http://hollenhundshepherds.com/
                                      • bullwinkle
                                        • May 2009
                                        • 107
                                        mods pls close thank you
                                        • Ted29946
                                          LG 50PG20-ua Plasma TV repair help
                                          by Ted29946
                                          I'm new to this so I hope I'm doing it right So....I picked up a LG 50PG20-ua Plasma TV (Someone's throwaway pickup) First power up no picture or sound
                                          Found power board to be bad and I repaired it. (Bad caps) Now all power volt readings are good. Still no picture or sound. I plugged in power cord, no click and the standby light on the on/off button comes on blue as soon as it is plugged in and does not turn off when button is push. I then pulled the main board off to look at it better and the initial inspection (front and back) I cannot see anything bad. Before I put the board back
                                          10-24-2024, 11:12 AM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • porfyriadhs
                                          Samsung Plasma PS51D6900DS Bootloop
                                          by porfyriadhs
                                          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                          Thanks a lot !!
                                          10-19-2023, 11:31 AM
