Samsung UN50F6350 display turns white intermittent
  • Pwtzz
    • Nov 2021
    • 10
    • Usa
    TV runs normally but after 10-15 mins of watching. The TV gets less than a second of white screen (see 5 sec video) then it continues normally, just for it to do again after about 10-20 seconds over and over. If the menu is out it does it to the menu as well.
    I check the boards for bulging capacitors but there's none, I reseated the cables as well.
    Help is greatly appreciated.
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
  • Diah
    • Feb 2013
    • 6460
    first test half screen by disconnect ribbon cable between T-CON and panel once a time. if the fault remain then its Gama chip on T-CON.
    BTW. these 48- 50.6ß size panel are absolute rubbish over all brands. so put in mind if you replace T-CON could be the issue at panel too.
      09-07-2024, 05:50 AM
    • Egidio85
      Samsung UE55F8000SZ Turns on and off immediately
      by Egidio85
      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
      This defect happens continuously, hearing the classic click of the relay every time.
      Power supply board BN44-00636B
      disconnecting the mains and lamps from the power board always causes the same problem.
      Is it normal that without anything connected this power supply turns on and off cyclically?
      any suggestions on what to check?
      thanks in advance
      03-11-2025, 12:45 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
