Samsung LN55B650T1FXZA 8 blinks
  • kevinm34232
    • May 2012
    • 1884
    I haven't opened this one up yet, but when plugged in the red standby light comes on as normal.
    When you press the power button, it starts blinking 8 times, with the 8th blink being longer, and then repeats.
    I didn't see anything about blink codes in the SM, does anyone know?
  • kevinm34232
    • May 2012
    • 1884
    Re: Samsung LN55B650T1FXZA 8 blinks
    I unplugged the main board from the PS board and PS turns on, and back light comes on. 390V at main caps, all other voltages look good. Main board again?
      OK, so far your power supply and inverter are OK. Try disconnecting the LVDS cable to the T-CON and see if you get difference blinking LED.
      • kevinm34232
        • May 2012
        • 1884
        Tried that already no difference.
        • kevinm34232
          • May 2012
          • 1884
          So I got a replacement main board, and I have the same exact problem. So if the power supply is good, there is only 1 more board and that is the t-con. Unplugging that board doesn't make a difference though?!?
          • kevinm34232
            • May 2012
            • 1884
            Is it possible that this main board needs a signal from the t-con board to work?
            • kevinm34232
              • May 2012
              • 1884
              Well I had the known main board from the 65" model and the 55" TV will power on, not completely but enough to show the 2nd main board was bad too.
                I am not sure if Samsung uses error signal from T-CON or not, try disconnecting the flat cables between the LCD panel and the T-CON board next, otherwise like you indicated, you only have the T-CON to try next.
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
