Technika LED 22-248 Wont Come Out of Standby
  • marc2j
    • May 2014
    • 7
    Morning all,
    This is my first time to the forum. I looked around some guides, opened up the TV looking for blown capacitors, but I couldn't see anything obvious.
    I was hoping someone could take a look and see if there is anything that sticks out like a sore thumb. Or if I do look to replace capacitors, where to start...
  • marc2j
    • May 2014
    • 7
    Re: Technika LED 22-248 Wont Come Out of Standby
    Hi guys - does anyone have any suggestions as to where to start?
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Hi. Welcome to the forum. So let me ask a few questions. First, when the tv is plugged in the standby light comes on but when you press the power button nothing happens? Second do you have a multimeter to take some voltage readings? If you do have one. Look on the power board and look at the connectors to see if they have any voltage readings next to them and see if those pins are at the corresponding voltages.
      • marc2j
        • May 2014
        • 7
        Thanks for the reply. The standby light comes on, but the remote or buttons which would normally poer the tv on giveno response.
        I dont know if I have a multimeter, I may have to borrow one and get back to you :-)
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • Crystaleyes
          Samsung BN44-00259A standby question
          by Crystaleyes
          Hi all.
          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
          08-11-2023, 05:15 AM
        • psssst
          Yamaha TSX 120 Standby Problem
          by psssst
          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
          03-01-2024, 07:25 AM
        • ChristianBr01
          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
          by ChristianBr01
          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
          04-23-2025, 01:48 AM
